Since 1) I don't really acquire the miles to justify a full shim kit based on usage and 2) the BMW shim kit has exploded in price, what is a good strategy for adjusting valves without buying the full kit? Measure each by each, then order individual shims? Aftermarket shim kit/shims worth considering?
Valve Adjustment--How to Do w/o Buying Full Shim Kit?
the Wiseco shim kit is reasonably priced at ~$65 (compared to the BMW kit) and it does the job."your BMW has how many miles!?"
2007 GX470
build/journal
ig: @zzyzx85
- Likes 4
I bought a Wiseco kit and it gave me a starting point. It only gives you 3 shims of each thickness. I needed like 8-10 of one of them and 5 of another, so I had to order more shims anyway.
If I were to do it again from scratch I'd measure each shim then order the ones I need to take up the gap.
You guys replacing at the recommended interval or waiting until you hear the familiar ticking sound? I don't know when mine was last done but I can't hear any ticking and sense no issues.3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
Wiseco 8.90mm Valve Shim Refill (shim size)Originally posted by WestBankM4 View PostWhere is everyone buying individual shims at? For instance, you used all 3 wiseco shims, you need 7 more of the same size.
I haven't been able to source individual ones except from bmw.
https://www.ebay.com/itm/31464729106...CABEgIG7_D_BwE
Lots of motorcycles still use shims to adjust valve clearance, so I got my 8.9mm shims from Rocky Mountain ATV MC. $2/piece. Plenty of other places online to get them but RMATVMC ships quickly in the west.Originally posted by WestBankM4 View PostWhere is everyone buying individual shims at? For instance, you used all 3 wiseco shims, you need 7 more of the same size.
