Best replacement cv axles?
    Just reviving this thread. I need a new left drive shaft. I have searched around. looked at Redish but they say they only ship to the UK. There are multiple aftermarket shafts. Trakmotive, Surtrack, FEQ, GSP and API. I could only find a review on the GSP. Both reviewers said they didn't fit, squeeled and lasted about 100 miles. Priced at +/-$100 I question the quality. There was one from Insane shafts that looked interesting. Has anyone know anything about it?
    Redish claims the part number has changed from 33207839467 to 33217839465. I found a ...465 but they cannot verify fitment.
    Any help appreciated
      I am surprised there are no aftermarket solutions for these halfshafts yet.
        Originally posted by tlow98 View Post
        I’ve used these. https://www.bmwmdev.com/shop/the-bmw...r-cv-joint-kit
        So have some other members. Pretty pleased. The stock ones had quite a bit of play.
        I used these as well, and 3-5k later the rotational play and clunk has returned to some degree. In my case, there’s roughly equal play in my rebuilt diff and these replacement CVs, about 1/2” at the tire for each. The car has almost 200k on those axles, so it may be an issue with spline wear, but I thought it was worth highlighting.
          I'd spend the money and get a used OE set and rebuild at a minimum. Its not too hard...just messy.
            Bummer. But good to know. My car will be up in the air for diff work, as you’re well aware, and I’ll check them then.
            I bought an OE CV for the driveshaft and intend to install that as well. The original has a lot of play.
