1) Assuming one has a cam alignment bridge and 2 cam alignment pins, why not deploy the bridge with pins inserted into the cams at all times to make sure the cams do not move during the "Vanos Rattle Procedure?" In my reading and watching videos, it seems people take off the bridge and pins only to eventually deploy it again to make sure the cams didn't move. Why? Why not keep it on for the duration of the procedure?
2) Near the end of the "Vanos Rattle Procedure" the instructions state to hand tighten the 2 side bolts on the intake and exhaust sprocket hub only to loosen it again by a quarter turn. What's the reason for doing this?
Thanks for the wealth of information you folks provide through this website!
