Installing driver airbag properly
    I did an interior swap and had to remove the steering wheel and air bag. When I tried to put it back in - I couldn’t put it back properly no matter how hard I pushed. It clicked into one side and the other side never sat in properly. In removing it - I damaged the metal mechanism that holds the airbag into place. I just purchased a new wheel and tried it again and the airbag had the same issue with not clicking properly. I managed to remove the airbag without damaging anything but need tips / advice as to how put it back properly. It looks really easy and I just put it straight in and push on both sides but that hasn’t worked for me
    Here is a picture of the airbag from the back. The clips look fine to me.
      Yeah when I did mine I don't remember it being that hard. Snapped in real easy. Here are some pictures of mine to at least compare something to when I had pulled it for some trim work. Also, what about the metal spring things inside the wheel? How do those look? I attached a picture so you can see mine, which didn't give me any issues. Perhaps one of those metal springy things is amiss? Wires getting the way a possibility too I guess.
        So you have two different wheels doing the same thing?
        Is it the same airbag on both?
        2004 Dinan S3-R M3
        2023 X3M Competition
          I've had it where sometimes the airbag goes right in and others I've had to stick a screwdriver as if I were removing it to get it so slip in. Seems like sometimes the retaining mechanism binds a bit and it just needs bit of help to retract.
            Thank you so much. These pictures were super helpful. There was one wire that was not positioned correctly which was getting in the way. I placed my wires same exact as yours and mine clicked in perfect. Really appreciated!
              You're welcome. I take a ton of pictures so I know how to put things back together as I take 'em apart!
