Originally posted by jet_dogg
View Post
THE M3 IS GETTING THE ANRI BUILD TREATMENT - Blown headgasket to build thread
I don't disagree with the above, my point was that the issues of the plastic impellers, that was resolved 20yrs ago, still pushes people to be scared of plastic impellers to this day.
A very simple mantra to follow is "if it ain't broke don't fix it". With time all those bullshit ass "upgrades" come to light as being shit ass upgrades. Take the radiator for example, with people wasting their money on csf garbage only to discover their car overheats and paying for the privilege of it doing so. No wrong has ever been done by sticking with oe parts. Conversely look how much it costs people who cheap out on parts to save a buck and it causes long term damage to their engines unknowingly, or, eventually knowingly after the fact the damage has been discovered. Even cubieman had an issue with a beisan oil pimp disc which was a 30+ page thread in and of itself.
And it’s possible the radiator was one of those lessons. And the worst part is it even costs more than the OE part.
Only the person that had removed the rocker rods (to replace the rockers)
The chain cover was cleaned to like new
condition.
The crank snout was cleaned as well from the old
grove.
New seal was installed and pushed in deeper so that
on the next crankshaft seal replacement the seal can
will be installed 1.5mm less that means the grove will
remain after the seal not before the lip of the seal!
New Chain, all new guides are already in.
Head is ready to be installed.
Regards
Anri
- Likes 2
Originally posted by ChapterM3 View PostThat's the thing - in my ownership I've never had anyone touch the rockers - so what's worse, a shop forgetting to replace them? or shops not catching they were missing in the past 5 years of my ownership? 🤦♂️
Originally posted by Anri View PostOne of the rocker arm has odd damage and was replaced with a good one I have in stock.
'00 R11S, '09 HP2S, '12 R12GSA, '00 Gray 332iT (SOLD), '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Japan Rot 325iT
Email to George@HillPerformance.com
Originally posted by George Hill View PostWhat do you do to counteract the potential failure from mixing and matching follower on cam lobes?
With a risk of having people jump into an argument
I must say that it's not a problem at all as long as the
rocker arm is in a good condition. I have done it many
times. On every S54 I rebuild I do polish the rocker arms
before I install them back.
Regards
Anri
Originally posted by Anri View PostThe crank snout was cleaned as well from the old
grove.
I can't see the old groove mark by the oil seal on this pic; did you do any polishing or only cleaning? I'm surprised that the oil Teflon seal didn't cause any wear on the meatal sealing surface.
Originally posted by Anri View PostWith a risk of having people jump into an argument I must say that it's not a problem at all as long as the rocker arm is in a good condition.
Sapote,
Thanks for your replies.
This is cleaned surface already.
Bellow is how they look like before I clean them up
Originally posted by Slideways View PostBecause it is in the TIS instructions to use Drei Bond 1209 silicone sealant in those areas you have pictured.
Do you make a difference between the Drei Bond and RTV silicone
used in the pic as everybody using ?
