There needs to be a reason for you to run a split mu pad setup. It affects bias and limit handling. For a car that dives a lot (soft front end) and xfers a lot of weight forward, you might want to run more mu in front, for a car that has rear wing and stiffly sprung front where the car stays level on brakes you might want more rear mu since you have downforce and more grip there, for a stiffly sprung car but that has rear gutted (weight distribution shifted forward) you might want more front mu. For a 50/50 weight distributed car but that sees a lot of hard downhill braking sections you might want to run less rear mu. For an underpowered front axle bbk (like 996), you can run more front mu. It depends what setup you have and what problems you are solving. If you are locking up tires, maybe the answer is not to back off pad mu but to get grippier tires, or adjust your technique and brake earlier and smoother to not upset the car when entering the turn not overbraking and carrying more min speed through the turn.
