Just curious if anyone has run into something like this...
Every now and then when coming to a stop, and only after about a 20min drive or so, the idle will hang a bit high (around 1000-1100 usually), and if I sit there long enough it will go into Limp mode with code P0506- Idle Air Control, System RPM Lower Than Expected. I have noticed that when the problem starts to happen and I blip the throttle, the high idle will rise higher and higher. I have also noticed that if the idle starts to hang high and I just put it back into gear and drive off, there are no codes and everything seems fine.
This all started after going to a CSL/MAP setup *with an HP-converted MSS54 DME*. Pre-conversion the car ran decent. I went with a Geoff Steel airbox, had my MSS54 DME converted, and Hassan at HTE remotely tuned it.
Things to note:
-All throttle sensors are new, Pedal was new in 2019
-IACV is new (actually took care of a slight idle surge)
-All throttle bodies are CLEAN and adjusted to spec per BMW.
-Original throttle actuator
-Adaptations reset
I have been meaning to do some logs to try to see if we can find anything but I just haven't had the time to do so since this is my rally car and I'm in the middle of a re-prep (we had a rough last rally). I had the thought of putting in my spare throttle actuator for shits-n-giggles but I have a strange feeling that this is all in the DME and more specifically something to do with the HP conversion (not the tuning)... I DO have another DME on hand (another HP-converted one) but I was unsure if I could just do a full DME Read and then transfer that to another DME or if there was more to it.
Thoughts?
Things to note:
-Adaptations reset
Thoughts?
