In re "up sizing" wheels and tires, the e46 m3, from factory, with 18"s, has a circumference of 81.6 F & 81.7 R iirc.
Our wheels, usually, are staggared, and for us to maintain that even diameter or circumference requires that we go down a profile (45 to 40, for example) when going 30mm wider (225/45 to 255/40).
Here's my question:
Why does a wider tire with same (18") wheel diameter spec and same profile have a different rolling circumference?
I can understand it when you've put that wider tire on the same size rim - the wider tire will be squeezed, and I assume, become a bit taller. But if you extend the wheel width by the same amount of tire width, why would that wider tire be taller?
Wouldn't it fit the tire just as well as the narrower tire would fit the narrower wheel?
When you look at Tire Rack ,for example, and you see they're measurement for diameter and revs per mile (225/45/18 is 25.9" / 802rpm), do we trust that's true no matter what wheel the tire is installed on?
And if so, what is it exactly then, that makes a wider tire taller? Same diameter of wheel (18"), same profile (45) just wider to fit the wider wheel, so smae amount of stretch. Why would a 255/45/18 be taller than a 225/45/18, if installed on wider wheel (9" versus front 8")?
Thanks
Here's my question:
Thanks
