Caliper guide pin lube
    I've used aye plastilube, it gums up on track weekends and I don't recommend it. Wd40 is a better solution I've found but still leaves a lot of room for improvement. I may try one of the recommendations from above
      This is what you people need: https://www.zoro.com/krytox-high-tem...ac/i/G1579116/
        Doesnt WD40 breakdown quickly? Anything I lube with WD40 needs constant re-application.
          Baller. Only $147.00/ounce !
            5% off, I'd better order two. lol
              These cars are 18 years old, they’re not dried up old ladies. They’re good to go.
              NSFW, and amazing.
