F8X M3/M4 CF Drive shaft mod
    Alright, I had a few free hours this morning and there was an open lift, so here we go!
    How it started:​
    Click image for larger version  Name:	IMG_6788.jpg Views:	137 Size:	119.9 KB ID:	322569
    A few minutes later:
    Click image for larger version  Name:	IMG_6791.jpg Views:	137 Size:	80.6 KB ID:	322566
    Click image for larger version  Name:	IMG_6789.jpg Views:	155 Size:	60.5 KB ID:	322565
    Click image for larger version  Name:	IMG_6794.jpg Views:	144 Size:	109.3 KB ID:	322568
    And another 30 minutes after that, we're all buttoned up again and ready for a test drive:
    Click image for larger version  Name:	IMG_6796.jpg Views:	139 Size:	118.1 KB ID:	322567
    This is the F80 driveshaft that EthanolTurbo had modified with e46 M3 flex disc and CV joints. It is exactly 5mm shorter than a factory M3 driveshaft. Because it's shorter, I did not have to unbolt or drop the diff or subframe to install it, as you can see above. This is a tradeoff, as there will be less spline engagement with the driveshaft and CV joint. I think 2-3mm shorter than stock would be the sweet spot if you're not using the telescoping F80 version of the shaft (which is a better solution overall, in my opinion). Install was easy, just like any other driveshaft, only made difficult by the shitty supersprint header joint.
    We measured before that this shaft is 80mm OD, versus the 75mm max OD stock shaft, so the math says that this carbon shaft should be much stiffer (bigger diameter, 50% stiffer material, likely also thicker wall) than the original and also bring in some of the inherent damping that carbon weaves have that steel does not. It's also one piece, although I don't think this is likely to have any real noticeable effect from the seat. We measured that it's 3.5lb lighter than the steel part, which I also don't think will be too seat of the pants noticeable, because inertially these math out to be very similar due to the larger OD of the carbon shaft.
    Because this shaft is larger OD, it's a very tight fit. This is only suitable for cars with non-raised, solid subframe bushings. My car has *non-raised* & solid subframe bushings with reinforcement plates (4-5mm thick, which helps gain clearance) and I had about 8mm clearance to the transmission tunnel. Any displacement of the subframe/diff under acceleration or due to adding subframe raising solid bushings is likely to put you at risk of hitting the transmission tunnel and disintegrating your driveshaft. Consider this fair warning if you choose to go carbon, and I cannot stress this enough. Carbon does not fail subtly or slowly.​
    Good news, I did not have to make any clearance to my unmodified exhaust heat shield.
    So what's the verdict? My initial thoughts say a very minor positive difference versus steel.
    First of all, since I'm in San Diego it's easy for me to make a quick trip to Mexico where I tested the car up to 120mph (with stock gearing) and had absolutely no noticeable vibration. I'm sensitive to vibration. Sort of OCD about it. In fact, I'd say that the car is ever so slightly quieter at speed. I was expecting this as it's a common noted difference, so there may be a bit of placebo here.
    When I initially took the car for a drive, I was pretty hopeful because I couldn't detect any semblance of the m-clunk. This changed once the car had warmed up. I'd say this was a mild improvement to the clunk (more of a thud now in my car), definitely less of an improvement than the rear end bracing made (my touring cabin X-brace and subframe-v-brace). Any improvement here is welcome, but it's not a magic bullet. Shift & shifter quality is largely the same, just with slightly less of the thud on a hard 1-2 shift.
    There is also an improvement during clutch take-up, it just feels smoother and a bit more direct - in the direction of, but not equivalent to, a Porsche. This is maybe the most detectable and biggest difference.
    There is no perceptible increase in the car accelerating quicker or revving faster that I can tell. Note that the math also generally agrees with this.
    On just one occasion, it did seem that I was able to excite some natural frequency somewhere around 40-50mph under WOT second gear acceleration after a 1-2 shift. It felt similar to a failing CSB, but I wasn't able to reproduce this, so it could have been coming from the road, as I was on a highway onramp in a landfill area.
    So overall I'd say this is mostly a smoothness, directness and NVH improvement, in that order. All effects are relatively minor but if you're OCD about NVH and needed a driveshaft balance like me anyway, I'd say go for it. It's an improvement. If you don't need a driveshaft, maybe wait until your next 'while I'm in there' opportunity. If you're debating whether to do this or a chassis stiffening mod first, *definitely* do the chassis stiffening mods first, you'll feel those a lot more.
    Hope that's helpful!​
    Which solid subframe bushings are you running? Are you running solid diff bushings as well? Do you have a picture of the tightest point of the driveshaft to the trans tunnel?
      This pic was when I had the driveshaft in and the diff moved due to shit poly diff bushings, close one...
      I don't have a pic now with solid bushings, but it sits dead center.
      I run cmp subframe bushings and millway diff bushings. Doesn't matter which brand though. Just stay away from anything poly.
        Yeah. Everyone once in awhile I need to install poly something somewhere and remind myself. lol
          Bimmerworld I believe, they are non-raising. Stock diff bushings. You want enough room that wearing diff bushings will not cause you to nuke your driveshaft. A totally blown out set of diff bushings will likely end with a failed driveshaft even with solid subframe bushings, it’s pretty tight, too tight for a camera to fit beyond what’s in the video.
          Avoid using CMP here as they raise the subframe up. VAC sells both options, that’s probably the safest bet. There are probably a bunch of choices but don’t leave it to guess work.
            Woah. That’s a significant shift. Which poly diff bushings were you running? I have AKG 95A in mine and would like to avoid running solid diff bushings so I can enjoy a freeway drive without a crying diff, but seeing how close that is I’m having second thoughts.
              Thanks for that. I’ll probably end up going AKG or Bimmerworld solid all around. They seem to not lift the subframe to compensate for reinforcement plates.
                So you're saying it does clear with the CMP main beam mounts that move it upwards?
                Do you think it would be an issue with the standard diff mounts and CMP main beam mounts?
                  Woah. That's a significant shift. Which poly diff bushings were you running? I have AKG 95A in mine and would like to avoid running solid diff bushings so I can enjoy a freeway drive without a crying diff, but seeing how close that is I'm having second thoughts.
                  I had the AKG 75D. The problem is the same for all poly bushings, you can literally push them in without much force. How is that supposed to hold up under load?
                  If you don't want to go solid, go OEM.
                    Yes, there's no issue with contact on the top side of the tunnel.
                    It should be fine with the standard diff mounts. The rubber portion in them is actually fairly small so the diff won't move a lot.
                      Sigh. I wonder where I’ll end up with subframe bushings raising it up, but subframe reinforcement plates lowering it down. Should net pretty close to stock location…
                        Sigh. I wonder where I'll end up with subframe bushings raising it up, but subframe reinforcement plates lowering it down. Should net pretty close to stock location…
                        Similar to where I am, I also have the same combo.
                          I didnt think of this. Thanks for pointing that out. Let us know when you do the conversion about the clearance please.
                            So the consensus is if you run AKG subframe bushing, this is a no-no?
                              Should be OK...I don't think they raise the subframe closer to the body.
                                I would recommend not using urethane or rubber subframe bushings with this driveshaft, including AKG, yeah. Not saying it will definitely cause problems, but the likelihood of problems is way too high to get a recommendation from me. Solid bushings is the way here.
                                As an aside, I went from AKG urethane to solid aluminum on my car and noticed almost no NVH change at all. And for comparison, I’ve removed things like solid RTAB mounts and urethane strut tower mounts because I was unhappy with the NVH they introduced. I cannot think of a reason to recommend urethane subframe bushings.
