Bumping this old thread, does anyone know if a 380mm rotor can fit a 19'' stock ZCP wheel? Stoptech trophys
375-380mm rotors/discs under 18" wheels
You'll need a spacer to clear the caliper but yes it will clear.Originally posted by BMWahba View PostBumping this old thread, does anyone know if a 380mm rotor can fit a 19'' stock ZCP wheel? Stoptech trophys2004 BMW ///M3 Carbon Black/Cinnamon 6MT
2005 BMW ///M3 Interlagos Blue/Black 6MT Dinan S3-R
Apex EC7 R18 wheels accept even 390mm brake rotors with good enough clearance due to their flat inner. 380mm fits with a LOT of clearance into them.
390mm on pic
380mm
there are quite a lot R18 models with the flat inner these days, due to the modern cars with the large brakes, like BMW M models (f8x) for example, where minimal brake diameter 380mm, and a lot of people, who prefer to use R18 wheels.
BMW offer even oem R18 rims (forged if i'm correct), which fits on 380mm - 513M style.
I think the killer track setup is going to be your 6 pot Brembos and brackets using OE E9X rotors that we can buy from FCPEuro. Looking forward to that group buy!!Originally posted by Slonik View PostApex EC7 R18 wheels accept even 390mm brake rotors with good enough clearance due to their flat inner. 380mm fits with a LOT of clearance into them.
i don't like to use e9x rotors on e46 platform. they have a lot more height (more "offset" to inside), 52.5mm on e46 compared to 62.2mm on e9x. so to fit them you need to cut or remove rear dust shields and even after that you will get too little gap between rotor surface and tie rod rubber boot (few mm only).Originally posted by robgill View Post
