m3
    m3
    Search the world's information, including webpages, images, videos and more. Google has many special features to help you find exactly what you're looking for.
    Sounds tune-related to me, but hard to say without knowing the setup. So many questions, MAF based? MAP? Stock DME or aftermarket?
    Generally speaking a high idle might be caused by:
    • Vacuum Leaks
    • Dirty Idle Control Valve (ICV)
    • Bad MAF
    • Faulty throttle body (one or more of the 6 isn't closing all the way or adjusted correctly)
    • Failing fuel pressure regulator
    • Coolant temperature sensor issue
    • Or like you mentioned above, tune related
    I would start by verifying all those things are correct, INPA should help verify you're getting accurate readings from most of those sensors. After that, I would start looking into the tune. Good luck!
