m3
Sounds tune-related to me, but hard to say without knowing the setup. So many questions, MAF based? MAP? Stock DME or aftermarket?
Generally speaking a high idle might be caused by:- Vacuum Leaks
- Dirty Idle Control Valve (ICV)
- Bad MAF
- Faulty throttle body (one or more of the 6 isn't closing all the way or adjusted correctly)
- Failing fuel pressure regulator
- Coolant temperature sensor issue
- Or like you mentioned above, tune related
