So I am finally taking the plunge and getting a 2 post lift for the garage. Our M3 is lowered quite a bit... Curious what folks out there like/dislike about the lifts they have used. I only have experience using a lift once or twice. The other vehicles I plan to have on it are a couple standard SUVs, and a RAM 2500 diesel. Because of the truck I am pretty much limited to a symmetric lift config. Have folks out there had issues loading the M3 onto a symmetric two post? I am pretty sure any lift I get I am going to need to put wood/ramps down. But mostly concerned about door clearance when trying to get in/out of the car.
Lift Recommendations?
I have scissor type lift .. 2 post probably gives you better access to bottoms than scissor type.. clearance for the door access should be ok (based from what i saw in the shop, you just need to position it to the middle)
during my shopping, the worry i had for 2 post was only on the balance .. i was worried about car's been tiled from the front of back ...(of course due to the cause of me, the human error if it happens)
I have access to a symmetric 2-post without a top cross bar (I think they call it a baseplate lift). The symmetric is not ideal for door opening on the M3. The arms are also a little too high at their lowest point and I need to drive onto raceramps just to get the arms under the side skirts.
It works great for anything up to a 3500 truck.
During my research, it seems that everything has its compromises. Almost every lift will work for every commonly encountered vehicle, but some are better suited to certain types than others.
I've always thought the underground 2-column lifts were sweet.
