E46 M3 OEM vs E46 M3 CSL/Mini vs F80 M3 Li-ion Battery
    So I stumbled on a deal for a F80 M3 lithium ion battery and decided to give it a try even though my stock battery is only a year old.
    I don't have a CSL/Mini battery on hand but pulled up a picture from M3Forum cache.(the image is tiny, sorry)
    Specs:
    CSL/Mini: 480CCA 34.4lbs
    E46 M3 OEM: 640CCA, 45.65lbs
    F80 M3 Li-ion: 860CCA, 29.85lbs
    E46 M3 Bosch OE: 790CCA, 46.15lbs
    i48CX Braille: 1520PCA, 11.15lbs
    The F80 M3 Li-ion battery is larger in dimensions compared to the factory AGM E46 M3 battery but it still fits without issues. I did some research previously and per F80 forum, the Li-ion battery has the electronics inside to protect it from overcharging which was my biggest worry. From the limited tested that I did, I have not had any issues. Everyone probably knows but, you can not charge a lithium ion battery with a regular charger so I bought a CTEK charger specifically for lithium ion batteries.
    Is the battery worth it with a $1100 price tag? At the moment it would not be worth it to me but that opinion can change if I find that it has a significantly longer life.
    I’d love to try one out too but damn that’s expensive for a car battery. Any idea how much longer these Li-ion batteries are supposed to last vs standard batteries?
    2004 E46 Imola Red M3 Coupe
    2015 F56 Pepper White Mini Cooper S
    2018 W205 Polar White C300 AMG Night Edition
      I think there are some cheaper li-ion batts. There was an awesome thread on m3f about them, and I can't remember the names but they were around $600-700.
      Current:
        Seems promising but at that price too rich for my blood.
        2004 Jet Black/Cinnamon 6spd ///M3
        Build///Journal
        IG: Khan_Art_
          Per F80 forum, AGM battery has a life of 350 cycles while Li-ion is at 3000-5000 cycles. Hoping that is what I see, would definitely get another if its true.
            What is considered a cycle?
              One 100-0-100% cycle
              two 100-50-100% cycles
              ten 100-90-100% cycles
              etc
                I've been running a 6 lb Braile GU1R lithium battery in my M3 for 3.5 years now without any issues.
                That said, it no longer sees winter use (though it's had a couple <30 degree starts) and I put it on a (lithium specific) trickle charger if I'm parking it for longer than ~2 weeks (... which I did with the stock battery, too).
                Because, at 6 lbs, it's not doing anything meaningful for weight distribution, and the battery cable going to the trunk is 6 lbs, I also mounted it under the hood, like the 4 cylinder e46s do. Enabled me to save the weight of the cable and gave me more trunk space!
                new battery location (and my super leggera washer tank):
                Extra trunk space:
                Bonus: I also got extra trunk space on the passenger side
                  Extra trunk space:
                  $549 bs $1100 for a battery that weighs 6x time more seems like a far better value
                    SIs the battery worth it with a $1100 price tag? At the moment it would not be worth it to me but that opinion can change if I find that it has a significantly longer life.
                    How quickly were you going through batteries? The standard batteries have lasted me 7-8 years each, so it seems like it's hard to justify Li-ion money even if longevity is the concern
                    Not really a fair comparison though. Obioban's setup is unacceptable for a daily driver (which his coupe no longer is). The battery capacity in that thing is about the same as a portable jump starter. It'll get you started a couple times, but you can't run much off it for very long.
                    Antigravity batteries are decent middle ground from a weight perspective: https://antigravitybatteries.com/pro...es/automotive/
                    The 60Ah versions (which is the lowest capacity I'd be comfortable with on a daily driver) is only 18ish lbs, but your cost is pretty close to the F80 battery at that point.
                      Not going through batteries fast enough to justify the purchase. I wanted a "stock" battery that weighs less than the stock AGM but without the headache to chargers or having a dead car after a few weeks. I used to have a lightweight race battery, that experience pushed me away from them probably forever.
                        I went with the AntiGravity at a whopping 12 pounds. Not cheap ($675) but the built in restart feature is nice for peace of mind. Just ordered terminal covers yesterday.
                        Feff
                        Click image for larger version  Name:	AntiGravity.jpg Views:	0 Size:	170.0 KB ID:	3076
                        MVP Track Time
                          Feff
                          Definitely an option but the H7 60ah which would be my choice costs more than what I paid for the F80 M3 battery.
                          Edit: AntiGravity would save another 10lbs(H7/60ah) so it's definitely a good option for whenever I need my next battery.
                            That's what it was called! Antigravity will be my next move for sure.
                            Current:
                              A stock BMW positive terminal cover (Part 61218375653) fits perfectly with AntiGravity. The negative terminal cover is a generic left hand coming via Amazon.
                              Feff
Name:	Terminal Cover.jpg
                              MVP Track Time
