If i’m running a 18 x 10 et 24 squared set of BBS E88’s
is it possible to fit a 245/35/18 in the front?
I’m currently running 265/35 zr 18
with a 10MM spacer to clear my coilovers from rubbing
265/35 zr 18 is pictured below
fitment is somewhat “aggressive” and will need -3 / -5
negative camber to tuck under the front fender
setup would be easier to run, if I didn’t have
to run a spacer on the front to clear coilovers
