I would have figured out how much the machine shop took off the head and the block before making an expensive guess. That would been a key clue. But curious to see how it turned out...hopefully well!
S54 schrick- build and timing issues.
Originally posted by CrisSilberGrau View PostAny updates on this, sorry for digging up old thread. Will be going through something like this next year as well.
Originally posted by bigjae46 View PostI would have figured out how much the machine shop took off the head and the block before making an expensive guess. That would been a key clue. But curious to see how it turned out...hopefully well!
Originally posted by BMWfanz View Post
For first build-surfaced block and head -surfaced head for 0.3mm, block- 0.1mm (on this setup- valves contacted to pison on vanos test). Second ruild- surfaced head 0.15mm. For safety run i've increased releifes on custom pistons (+1.5mm intake +2mm exhaust)
According to a post on m3cutters, 0.3mm skimmed off the cylinder head is the max for a factory Elring gasket. Most are able to stay below 0.2mm. Your's was 0.4mm, so a thicker Cometic head gasket might have avoided the piston to valve contact.
