I'd love to do a set of street cams. Do most people think the 288/280s are the way to go for a mostly street car? I'd rather not loose midrange power for a few hp up top.
Vanos work, good time for cams?
IMO 280/272s are better than 288/280s for everything other than raised compression, 8700rpm, etc builds.Originally posted by Ob917 View PostI'd love to do a set of street cams. Do most people think the 288/280s are the way to go for a mostly street car? I'd rather not loose midrange power for a few hp up top.
And, fwiw, Schrick says DLC followers are recommended for 280/272 but required for 288/280.
I’m at about 10k miles on mine with stock rockers with no issues to report.Originally posted by Obioban View Post
280/272s would run fine with CSL sw correct?2004 Silbergrau Metallic 6MT
Anything other than actual CSL cams should ideally be tuned. Both the 280s and 288s run well enough on the CSL tune that you can get away with it. Though the 288s benefit from tweaking the dme parameters to compensate for the pumping losses introduced by the bigger cams.Originally posted by Cubieman View Post280/272s would run fine with CSL sw correct?
Thats when I did mine. But my head took a beating from vanos being vanos. So I rebuilt everything. Doing it again, get a fresh head, OE everything, throw cams in, tune.2004 BMW ///M3 Carbon Black/Cinnamon 6MT Dinan S2 FBO NA Build
2005 BMW ///M3 Interlagos Blue/Black 6MT Dinan S3-R+
2019 VW GSW S 4MO Platinum Grey/Black6MT Daily
