E46 M3 Cluster Not Working
    Originally posted by S54B32 View Post
    Haha, now way... the guy with one of the badest reputations in Germany
    I wouldn't have posted them for engine software, cluster repair is easy enough.
      Even easier, just unsolder the ROM chip from the bad gauge cluster and solder it into the new gauge cluster, bam done. No need to reprogram or anything. I think there are a few different models of cluster though, so you need to make sure you get the same as whatever you have now.
      My daughter's gauge cluster died in her e46 and this is exactly what I did, got another cluster for $20 and used my hot-air station to swap the ROM chip over. No tamper light, mileage the same. I do recommend using a hot-air station if you have access to it, the rom chip is very small, perhaps 5mm square in size.
      Problem is, they changed the type of eeprom from e46 early to late clusters, so before swapping check if same time of eeprom (like marking with M35080/080DQW, socket is SOIC-8). If you don't want to buy hot air station (highly recommend!) you can buy "chip quick", look it up on YouTube for diy's to solder out a chip.
      …under construction.
        I would also hit up this guy, he's help fix my cluster on multiple occasions.
          Yeah, this. Make sure the replacement cluster is the same. If not, you'll have to reprogram it. And using a hot-air station is highly recommended. It's a very small chip.
          That is awesome and a great idea and solution! Would you happen to have a pic of the ROM Chip location on our clusters? I definitely need to try this ASAP LOL
          It's really pretty easy, the hardest part is getting the cluster apart. Obviously, take apart your broken cluster first trying not to break it so you can do it on the new one successfully. I'd also recommend watching a few videos on how to use a hot-air station and trying it on an old broken motherboard (or something) to remove a few chips to get the hang of it.
          This is the chip
          It's this little chip in the middle here:
            This is the chip
            That's awesome! Thanks for the info
