The 3DM Ohlins "TrackDay" Suspension Kit spring rates as 400/630 front/rear. Does this sound like a good solution for a mostly street driven full-weight M3 or would someone recommend different spring rates?
Mike
It's a bit stiff in front relative to the rear. I think a 350/630 combo is closer to ideal for me.
Lowering springs are rarely an advised method of lowering a car.
Do you know what roll center correction is?
When done correctly, there are no inherent drawbacks of lowering a car, and some definite positives.
I think there are surely still drawbacks on the road, and as I referenced, that's the "more" I was referring to. But I'm not in a position to argue that point.
Either way, I should have added context to my original comment, but this thread is about lowering springs and street cars, and that is the application I was thinking of. Not high dollar coilovers.
I've been running the B4's, OE mounts, eibach springs (with hotchkis sways) and PS4S, and it's an acceptable ride quality given how stiff the chassis is. I would suspect OE Sachs would ride about the same.
From what another senior owner has told me, the b8's, lightly trimmed, with the plates do help the crashing. Ive been wanting to order a set of B8's and swap them in with the Turner plates that have been sitting unopened on my toolbox for a year, but I suspect it'll be another year before I get around to it.
I currently daily an S6, and my gosh is it noticeable how stiff the 46 feels when I do drive it. I'm not that old, but at 35 I have no interest in commuting with this old chassis.
Hi all, im new here, from Australia i have BL92 E46 M3 RHD SMG
just got quoted $4100 AUD for standard replacements,, i found sets on eBay from the U.K, though the seller says this is not suitable for my car ? check my picture
Can anyone assist ?
I need standard replacement shocks and springs, i have 110kmiles on it now
I checked pelican parts, though springs are not showing up!
Just bought the front strut bearings and spring pads, with hardware
I'd get the OE Sachs (not Genuine BMW) or Bilstein B4 (Touring) or maybe Bilstein B6 (HD) shocks/struts. I don't know if Australia cars are Euro or NA market, but I think there is a difference in struts.
Upon further thought I'm going to revisit the settings on my fronts, as perhaps a stiffer than average setting would go a ways to mitigate some of the bouncing and chassis shattering impacts from full compression scenarios. I've been mostly thinking about bump stops and ways to increase suspension travel but that's probably the first place to start. A lot of general advice or discussions in the 20+ years of archives have come from the angle of dialing it towards OE-like stiffness for 99% of drivetime scenarios, whereas the thing that bugs me most is the 1%.
If you're talking about Konis, cranking up the rebound will only make the problem worse, as it will tend to induce jacking down.
And I doubt that Koni or Eibach or H&R or almost anybody else has put much thought into bumpstops for this chassis.
I'm going to play with it, but I was thinking the opposite of what you're saying if I'm understanding correctly. i.e., turning them firmer to reduce jacking down and increase damping on compression to make the most of the reduced travel when it comes to massive potholes and the like. I definitely have too much bounce right now, to the point where the throw distance of my headlights is oscillating too much on even mild / moderate road imperfections.
'04 LSB Coupe 6MT
All my money goes towards maintenance.
Koni yellows, and other mid tier dampers with 1 way adjustment, can only speed up or slow down rebound. There's no stiffening - that's on the spring though speed and vehicle weight are factors too.
You want a damper that releases the springs' energy in a controlled manner, not too fast (bouncy, loss of control) but not too slow either (leads to packing up where full stroke isn't reached before the next bump and thus you have compromised travel).
Konis always seemed best to me at full soft or with just a small amount of slowing rebound down, matched with stock like spring rates. Once trick is to continue to slow them down further as they age and lose pressure. Higher end stuff like MCS and Ohlins, with 1 way adjustment, will have compression affected when adjusting rebound.
I'd still take a non adjustable B6 over koni yellow no contest.
Why? I considered them but they sit a little higher so I went with the Konis
"Bilstein makes amazing shocks - they are mechanically simple, parts are dirt cheap and readily available, and the innards of their street shocks and their full-race shocks are identical. Crack open a Bilstien street shock, and inside are the same parts as inside their NASCAR shocks. That means that there is a simple conversion process (involving welding a boss onto the shock body to fit a Shraeder valve into the gas chamber) to turn an off-the-shelf street Bilstein into a full-race, user-serviceable, user-revalvable NASCAR Bilstein."
I am currently running Eibach coilovers and ride height is about 13.75 front and 13.5" rear. With the mason X brace and front strut brace the ride is just too stiff and bouncy for street use and car does not feel anywhere near as planted as my Z4M on B12 pro kit. I absolutely love how the Z4M rides. Currently the E46 is just not confidence inspiring. So I was thinking to go with Koni yellow and either Eibach or H&R springs for my E46. I know the Eibach are really popular but seems like H&R sit a little lower and have a more even drop. Does anyone have experience with the H&R and would be able to comment on ride quality? I don't want to end up with a harsh bouncy ride all over again. Need some help choosing between the two springs. I am afraid the eibach will leave too much of a wheel gap otherwise I would pull the trigger on them.
Only seeing this post now - haven't read any of the 7 pages but wanted to chime in with my experience on the Koni yellows + Eibach spring setup as I've been running this setup for years now - I still stand by my review I made in 2020, and still love this setup!
Hey Everyone,
I bought and had a Koni Yellow kit with Eibach springs installed and wanted to write a quick review for anyone looking to get this setup. I debated forever on whether or not to go with Dinan springs over the Eibachs but after a lot of research it seems that Eibach for me was the right move considering the
I went through that thread in detail and it was very helpful, especially the pictures posted and the comparison between B12 kit and Koni kit which made me go with the Koni in the end. I expect the ride to be similar to my Z4M on Koni/Eibach. You can actually feel the spring compression and rebound on that car where as on the E46 everything feels stiff and just bouncy. I think I am getting too old for coilovers and just want something more OEM+.
2007 Imola Red Z4M Coupe
