I have taken measurements of the sprockets, and the surface that nests against the retainer plate is 2.5mm proud from the mating surface for the hubs, the depth of the cavity for the diaphragm spring assembly is 7mm, this means that...
For "A" parts there will be 1.5mm of spring compression
For "B" parts there will be 1.25mm of spring compression
I have made some quick math, but will do it fully tonight, however, there is at least 40% more preload force on the "B", or S62 items. So the delta is not some, is quite significant.
