Hey all,
I’m having some issues with the CAN BUS in my car. As a result, my ABS, coolant temp gauge, and radio are not operating optimally/at all.
Background info: Last year, my alternator was killing my brand new battery. As a result, I got a white screen of death on my older aftermarket radio and my coolant temp gauge needle would rest on red. I quickly replaced the battery and alternator and the car has been fine since.
I tried installing a brand new AVIN Avant 4 headunit recently and that install didn’t go as planned. The unit receives power once you plug in the 17-pin adapter + CANBUS module with the car (Amber backlights come on for about half a second) and quickly cut off. Radio won’t power on. I put back the stock radio and with a few tweaks ended up working with no issues.
P.S. I replaced the amp in the trunk and verified all fuses and relays are working well so that can be ruled out.
My coolant temp gauge works but there’s no Amber backlight and if the battery is ever disconnected and reconnected, the gauge will act abnormally again (in the red). After a few drive cycles, it will return to normal.
I decided to scan for any potential codes with INPA and low and behold, a new error code showed up — Error 86: CAN-bus DME
I tried communicating with certain parts of the car such as the instrument cluster and INPA couldn’t even connect.
Then I took a look at the DME connectors and all seems to be ok. This leads me to believe that the transceivers for the CANBUS in the DME or any capacitors/transistors are fried.
Could the alternator frying my batteries (2) cause the DME to permanently lose connection to certain modules of the car? If so, is my best bet just grabbing another fully-operational DME? Car drives fine otherwise but I’d like to get this sorted out. Thank you!
