CF doors by Carbon Microsystem
  • sdwz_m3
    I looks like a carbon/kevlar twill. If it is, then it would add toughness and reduce the splintering if compromised.
    I wonder how well it will hold up with the window mechanism. Not trying to be a naysayer but lightweight carbon doors aren’t that practical for a street driven car.
    I know Sub2Speedhouse (IG) picked up a set of these and began transferring over components. I'm not sure if he's putting the windows back in though...
  • bigjae46
    Originally posted by sdwz_m3 View Post
    The inner most layer of the outer shell looks to be kevlar?? OP could you confirm? Also, appreciate you documenting your results here.
  • sdwz_m3
  • bigjae46
    Any imperfection on the plug to make the mold will transfer over to the final part. Ideally, the original part would be sanded, blocked and primed smooth. I’ve seen many of these doors come gel coated because no one is going to use a new door…hence the $1900 price.
    Not an expert on paint but that ding is going to be impossible to remove with just clear coat. If the intention is to expose the CF…you’re kind of stuck
    5.4lbs sounds really light. I’d be concerned with the toughness of the part. Carbon is stiff and strong until it yields and then it will pretty much lose all of this strength once it yields.
    I’m in the process of making a right door and my outer shell by itself is 6lbs. My car has a roll cage but I wouldn’t use fewer layers of carbon that what I did for the right side. My left side door is a little over 10lbs fully dressed, that one has a full core layer and a partial core layer - could do without the partial core layer which would save maybe 1lb. I also used a layer of kevlar in each door to increase the elongation and toughness properties of the structure to reduce the chances of shattering and splintering.
  • usdmej
    Originally posted by e46IX View Post
    How do they install the metal crashbar on their doors? Rivets? Epoxy?
    the OEM crashbar bolts on so my expectation is that it will also bolt on to the CF door
  • e46IX
  • usdmej
    reserving this for potential DIY info
  • usdmej
    started a topic CF doors by Carbon Microsystem
    this is a continuation of a thread that will unlikely come to completion due to the OP getting himself banned. i went ahead and purchased a set of carbon fiber doors directly from Carbon Microsystem and the intention here is to provide the community with a cleaner and more transparent representation of the product
    quick background on the company Carbon Microsystem
    • based in Latvia
    • seems to have been around for a while with a focus on cf parts for older Toyota Celicas
    • parts are made to order
    • communication as of today has been excellent. they respond promptly (and in english) to emails. i've gotten very thorough answers to every single question asked.
    pics of the doors received
    Click image for larger version  Name:	PXL_20240917_052406991.jpg Views:	0 Size:	113.4 KB ID:	278935
    Click image for larger version  Name:	PXL_20240913_071906308.jpg Views:	0 Size:	107.0 KB ID:	278936
    quick rundown on the doors themselves
    • full carbon fiber, complete replica of the oem doors so everything stock (door panels, windows, door actuators etc) transfers over
    • 5.4 pounds each door (oem door weight TBD, but potential for ~60 lbs total weight savings)
    • debatable safety equivalence. we're driving around in 20 year old cars here so the bar is already pretty low for crash safety
    • 1900 euros base price
      • +500 euros for a preinstalled oem metal crashbar (you can transfer your stock one over)
      • +80 euros for in house clearcoat/polishing (would not recommend and will expand on that later)
      • +300 euros for custom carbon fiber colors
      • shipping quote was $400-600 at the time of request, expect to pay customs fees on top of that
      • they are open to group buys (lol)
    • shipping was fast and packaging was excellent, doors were delivered undamaged
    Click image for larger version  Name:	PXL_20240913_071852899.jpg Views:	0 Size:	83.4 KB ID:	278937
    this sticker is unfortunately applied at the beginning of the production process. if you want it removed, they provide instructions on how to sand just enough to get them off.
    Click image for larger version  Name:	PXL_20240917_052135746.jpg Views:	0 Size:	54.6 KB ID:	278938
    there are small imperfections on the outer skin of the doors. the doors were created using a mold that was made from a (understandably) used door so the imperfections have been transferred over. my door has a small ding in it (what i'm pointing at with my finger) and from some angles you can see some patches of waviness. the door in the previous thread also had a door ding that looked worse than mine. seems like they made some repairs to their mold but the end product is still not perfect.
    because of this, i don't think there's any reason you'd want to order these doors with the clearcoat option. if you're going to paint the door body color you're going to have to sand off that clearcoat anyways to properly prep/level the surface. if you plan on keeping the the weave exposed i suspect you'll still see the imperfections . . . unless the clearcoat is thick enough to hide it? maybe our resident cf expert bigjae46 can chime in on that
    this thread will be updated as the doors go through the process of prep/paint/installation. unfortunately i can't give a guaranteed timeline for this but hopefully the information that makes it here will help others with deciding if this is for them or not
