The hole is definitely not 35mm long, I remember measuring. I do not recall the exact numbers but my memory vaguely reminds me it was in the 20mm range.
The bolt is 35mm long, but obviously the vanos, and the dowel area take up a big portion of it. So it just needs threads at the beginning really.
). Was initially concerned that the previous helicoil repair might have caused them to drill the original threads out to a larger size than the time sert needed, but that wasn't the case in the end. For some reason, I actually did not need to resize the dowel after inserting the time sert. The depth at which my time sert's lip sits is basically identical in depth to where the threads begin in the identical unruined hole on the right side of the VANOS. My guess is that whoever did the helicoil drilled a deeper seat and it worked out perfectly in my favor.
