Exhaust question (Supersprint)
    Perfect! Somehow overlooked his post in the thread. Much appreciated!! And thank you again for taking the time and effort not only to create these but allow all of us to purchase them easily.
      Dumb question but the holes used to mount the bracket to the transmission are threaded on the transmission casing right? Also curious if it’s possible to install the transmission support bracket without removing the plastic transmission shield?
        Happy to help all the like minded NVH haters out there!
        Yes, the holes are threaded in the casing and no, it is not possible to install without removing (or at least pulling away really hard) the transmission shield. It's a tight fit under there
          Just ordered this and wanted to thank you....
          Sincerely,
          The NVH Haters Gang
            Bry5on you are the man! Your bracket to secure the pipes together with the two exhaust clamps right by the section 1 to header connection solved the annoying rattle/resonance I was dealing with. I decided to try installing one at a time and didn't have to use the transmission bracket. Glad that I have it if I deal with potential further resonances in the future. Thanks again!
