Slon Wall NVH
    Slon Wall NVH
    Question for those running the Slon rear wall/bulkhead: have you noticed increased NVH (emphasis on the N) after the install?
    In my car, the wall was acting as a speaker and resonating quite loudly at ~201 Hz. Was very obvious at speeds >60 mph with the rear seats folded down.
    Found that if you put light pressure on two spots on the left and right sides of the brace, the resonance goes away completely:
    Over engineered a fix for my car, but am now wondering if two of those snare moongel dampers (or similar) placed in those two spots would be enough to quiet it down. Anyone with this mod want to give that a shot and report back?
    Zero here
      Originally posted by Advorsor View Post
      Zero here
      Hmm, what subframe bushings are you running? Any vincebar style reinforcement installed?
        #trackcar
          What is the purpose of it in a car with rear seats?
            "30% increase in torsional rigidity of the chassis"
              No vincebar and IIRC, subframe bushings are standard Powerflex poly
                Interesting. I'm guessing the bolt through design of the front vincebar cups combined with my solid subframe bushings contributed to my NVH. Vibrations at the subframe travel through all the solid stuff and resonate at the panel.
                Obioban IIRC you have solid subframe bushings, a vincebar and this brace. Yours behave similarly?
                  Not that I’ve noticed, but I haven’t had the seats folded down since I installed the wall. I was thinking about going for a drive with them down after seeing your post, but taking the child seat out is a big pain.
                    Per BMW, chassis stiffness:
                    • BMW E46 Sedan (w/o folding seats): 18,000 Nm/deg
                    • BMW E46 Sedan (w/folding seats): 13,000 Nm/deg
                    ​Purpose is getting some of that for ourselves.
                      With measured results!
                      Write something... Okay, i'll try (sorry for my English) :D. Hello guys and girls! I was mainly offline on the forum during summer season, cause we have a lot of local work, our customer's cars went "time attack" events, a lot of trackdays etc, and by the way, one of our M4 took 1 place in Russian Time Attack
                      Yeah fair enough. Getting back there with the nogaros is no fun. Let me know if you do test this, fairly sure a small square of damping material on the wall is all that's needed to quiet the resonance. If not, seems pretty easy to find a way to wedge something between the wall and seat backs at those two points.
