Originally posted by sapote
O2 sensor heater DTC
o2 heater is not working and I think it's the reason why the O2 took more than 6 minutes for the DME to close the control loop as I mentioned before.Originally posted by x Spades x View Post
so now it comes down to the heater. For some reason, I don't think evap will ever ready.
But you had measured the heater voltage on the wires and I remember there was 12v across the heater 2 wires. Can you double check the voltage on the two wires again with cold engine running?
Evap takes many driving cycles to set, but the smog station will waive this.
Originally posted by sapote View Posto2 heater is not working and I think it's the reason why the O2 took more than 6 minutes for the DME to close the control loop as I mentioned before.
Ok will do today!
thank you so much for your continued support! ❤️
Agreed but 11.5 seems like a larger delta than i would expect at idle.Originally posted by sapote View Post
It's normal for volt reading from obd is lower than directly measured voltage at batt.
Measure voltage at battery during idle using a multimeter to confirm if alt is healthy or not.
Ready even without driving the car?Originally posted by x Spades x View PostHey Fellas,
Sooooo after this long journey, I took out my ecu and drove it down to someone in NYC.
"I don't know what happened, but I magically got it back 4 days llateral everything says ready after installing"
I will be deleting the cache on my phone and will be throwing it in a lake.
Same Dme but with new firmware? Did they repair or only coding?
Great news!
Yup, didn't drive one mile. Popped it in, started it up, everything was ready. Took him 2 days... (all of this is allegedly, lol). Same DME... he tried to overlay the changes with the current tine, but it wasnt taking. So he flashed to a stock tune, adj for my cams, and coded that one.Originally posted by sapote View PostReady even without driving the car?
Great news!
now I just have 2 more nagging issues... the upgraded injectors (made a post) and I get a tranny cog light when the car idles for like 15 min. It still drives fine, but it's weird. Every once in a while, ill get a "double blip" when downshifting.
Thoughts?Last edited by x Spades x; 01-19-2025, 05:10 PM.
The master knew exactly the memory locations to set all of these flags ready, and somehow bypass the power interruption which normally would clear all emission monitoring readyness. I wonder the next smog time in 2 years how the car will behave.
On the SMG light, the cog light popped up in neutral and idling? Read smg error to see what in there, and while in neutral check how long the pump stays off and running time.This will tell the condition of the pump and how bad the internal leak is.
