Ruined oil pickup tube
    In the middle of an engine rebuild. Upon assembly, I over tightened and ruined the thread in one of the nuts attached to the oil pick up tube. The screw doesnt really hold now, and I'm looking for alternatives to replacing the oil pickup tube (expensive).
    Has anyone been in the same boat before? It's the middle one, if that helps.
    Drill/tap to accept a bigger bolt?
    Edit: or get a new one. They're not terribly expensive, even when new: https://www.ecstuning.com/b-genuine-...e/11411406405/
      I'd try and find a used one from an engine part out.
        You could also have someone weld a nut on the back side.
          ^^^+1
          Budget CSL MAP Conversion
            If you're able to access the backside of that bolt with a tool, you could use a longer bolt and put a second nut on. To avoid it coming loose over time you could put a distorted-thread locknut there (don't use nylock as the plastic gets soft with heat)
                Replace it. Used if possible, new if necessary
                  I have pretty much every internal part so if you decide on a used one, I have it. PM me if interested.
                  2003 Carbon Black - Karbonious CSL intake, CSL DME w/MAP, SSV1 headers/Catted Section1/63.5mm Section2, Shrick 280/272 cams, Lang Racing Stage 1 cylinder head, Eibach Pro Street S Coilovers (500#F/600#R), GC Sways, AutoSolutions SSK, Motorsport 3.91 rear diff, BBS RGR wheels, Streamline CSL front bumper
                    If my wife hadn't thrown mine away I'd send you mine.
