Karbonius CSL Roof – Tips for DIYers
    That's surprising...seems most videos suggest they only used one(200ml). Good callout. Consumables are adding up $$.
    One other thing I noticed is many videos (Tek, IND, AJ Hartman) brush the adhesive on to the perimeter, but then don't go back and put another bead.
    I think that’s why I used more than the guys in those vids. I brushed the adhesive on + added a bead in a zig-zag fashion following BMW’s install guide. It’s extra work and may be overkill, but this is a one time install so I wanted the peace of mind.
    997.1 GT3 Carrara White/Black
    C43 AMG Diamond Silver/Red​
      FYI...Amazon sells Buck Panel Bond that comes in a 400ml cartridge for $65. I had about 1/3 of the cartridge left over after the roof.
        Tempting. I would be happy to use this for the roof, but I need to bond the roof bow as well so will probably just go with 3M 07333.
        🔹 2001 M3 Laguna Seca Blue
        Instagram: link
        Build thread: link
          Thanks for the great DIY. I've been parsing through it in detail. Also curious how yours went Heirforce1
          I'm sure I'll have more questions but for now:
          -Why not use spring clamps(on the front and rear)? They seem much easier to use. Regarding clamps, my understanding is something strong is obviously needed, but not too strong as to let the panel bond do the work. Thoughts here?
          -I see in Tek Motorsports video he used expanding foam, (3m 08463) to fill the gaps where you used windshield adhesive. Since this is just for nvh dampening it seems like a good solution, but maybe unruly to work with. Wondering if you considered this, and how the results were filling the gap with your windshield adhesive method.
          Mine went really well, finished the project last August and was able to enjoy the car for the rest of the season before putting it away.
          ended up using some spring clamps on the front and rear, but I think a part of using the C clamps is getting the tension you want. If you can use a lot of spring clamps to get some decent clamping force, it should be fine, but the goal would be consistency of clamping force to make sure the front and back are evenly bonded.
          The one thing I suggest is using dynmat or something equivalent on the under side of the carbon roof after installation. I trimmed and rolled dynamat onto the underside, and after everything was reassembled, there is 0 NVH, rattles, creaks, or any noises. It feels like a OEM piece from a modern BMW.
            I’m sure there’s no harm in adding dynomat, but I’ll state my experience anyways. I didn’t add anything like that to my roof, and I have zero NVH issues. I think the key is to properly apply windshield adhesive on the front, middle, and rear bows.
              Thanks Heirforce1 . So you used them in addition to c clamps? I ordered some of these in 6" but they seem a bit small. With that said, I'm not so sure significant clamping force is desired...
              Instagram: link
              Build thread: link
                My roof is officially on order(will take 4wks). Currently collecting tools and consumables. Went with 3m 08609 for the bows(nvh reduction), 3m 07333 for the roof perimeter and center bow(en lieu of welding). Skipping the primer and thinking to just touch up the bows with paint where the original noise reducing padding gets removed(the 08609 apparently adheres fine to paint).
                Instagram: link
                Build thread: link
                  You’re welcome to borrow my one time use tools. Just pay for the cost of shipping and cost of tools, and I’ll refund the tool cost once I get them back in good shape.
                    man, this is enticing me to try and pull it off.
                    I never really paid cf roofs much mind until i saw one at a meet on a nice clear sunny day. looked spectacular, and could be an avenue to deleting my sunroof...
                    2006 BMW ///​M3​
                    ig: @marecki.e46
                      Appreciate that! I figure i'll just sell the double cartridge gun then keep the rest of the tools.
                      Do you recall what size rivets you used?
                      Instagram: link
                      Build thread: link
                        Can I get in on this? The 2 part gun I have doesn't work with the 08115 cartridges. Would probably be sometime after May once it warms up here.
                        Mike
                        02 M3 Titanium Silver / Black
                        11 Tundra SuperWhite / Black
                          Correct, I used them in addition to the c clamps. But I agree with you, I don't believe the clamping force is as important as even clamp force distribution. There is a certain amount of clamp force you would need, but its not as great as you'd expect.
                          I really enjoyed doing mine. If you were closer to me I would offer to lend a hand. Also suggest getting decent rivet drill bits, or a few back ups. I went through 3 bits (used cheaper amazon ones) but it worked out well in the end. The rivet chisel was also extremely important and made light work of the rivets after I had them drilled out. The roof basically lifted itself off.
                            Thanks for pulling this all together in one place! I'm about to do my roof and was doing some research on adhesives that I think is worth sharing. Most alternatives to the factory 2k urethane adhesive (which is harder to get in the US) suggested are hard epoxies which can fail in brittle fracture on impact.
                            If you value safety and energy absorption in an impact, instead of using something like 3M 08115 epoxy you should consider LORD 7545 A/F. It is a 2K urethane, similar to the factory choice, with similar lap shear strength and even more toughness and elongation at break. Specifically the F version also has a 45-65 minute working time, instead of 10-15 minutes, which should make it easier to do a quality job by taking your time. Be sure to use a primer on any bare steel to get the full bond strength performance.
