Has anyone here weighed their vehicle rather than subtract the weight by each change?
I recently had the opportunity to weigh my car, which I acquired not long ago, and I was somewhat disappointed with the outcome. I had anticipated the weight to fall within the range of 3,200 to 3,275 lbs, but the actual weight came in at 3,341 lbs. My car is a 2004 E46 M3 Coupe, originally equipped with the SMG transmission, which has since been converted to a manual. The vehicle has undergone several weight-reducing modifications, including:
The vehicle also includes a welded-in rear half cage, which I estimate may contribute an additional 50 to 75 lbs. Despite the extensive lightweight modifications, which generally align with common weight reduction mods among members seeking to reduce weight, I had expected the weight to be closer to the 3250 lb range, even with the added weight of the half cage.
Looking ahead, I plan to further reduce the weight by installing a lightweight battery, Ground Control sway bars, an OEM CSL rear trunk, OEM CSL front door panels, and CF Recaro Pole Position ABE seats.
My ultimate goal is to bring the weight down to the 3,000-3,050 lbs range, but given that many common lightweight modifications have already been made, achieving this target seems increasingly challenging.
For those who have weighed their cars, what results have you experienced?
- Carbon fiber roof
- Recaro Sportster seats (driver and passenger)
- Rear seat delete
- Armrest delete
- Hard Motorsport front door panels with front speaker delete
- Air conditioning system delete
- Carbon airbox
- Removal of rear M tire repair kit
- 18” BBS RGR wheels
- 355mm front and 345mm rear big brake kit (BBK)
