I finally got to work on a project I've been putting off for a while. My car is a dedicated track car, and this is more of an intermediate/fun project until/if I decide to splurge on a CSL airbox.
My current setup is a K&N Filter with an aluminum pipe running to an ECS Silicone Elbow to the stock airbox. This was a cheap alternative to switch back from a velocity stack setup. I want to provide better heat shielding to this and a more direct air feed. I plan to use the headlight intake duct as the sole air feed for the engine. This frees up the ability to use the fog lights purely for brake ducting and ditching the kidney grill feed. This is likely net neutral in terms of weight, but allows me to close off the kidney grills and brake ducts as I start experimenting with cooling.
I was hoping for insight if anyone has done similar, and if the volume of airflow is too low for the S54. See the pictures attached for my work-in-progress airbox, which I am making for the filter. This will have an 88mm opening at the front that takes a tube as a direct feed from the headlight opening.
My expected benefits:
Let me know your thoughts as I'd love some feedback on this!
- Contained airbox with direct airflow feed, less heat soak
- Individual control of the kidney grill & brake duct openings without sacrificing intake air
- Too little airflow will be supplied through the headlight intake to properly feed the engine
