Castor Angle @ Alignment Shop
    Hi All
    I needed an alignment after raising the car back to stock height and new shocks,
    I assume from the report, the shop missed the castor angle alignment?
    Just need more info, before making another booking
    It's not adjustable if the car is stock. Others may know of hardware changes that can get you that adjustability, but I'm not familiar with that. I'd say if it is "out", could be some suspension components are out of spec (bent) or something.
      Not adjustable unless you have fully adjustable camber plates.
        Thanks for helping me out
        DataBank calls for 7.4 degrees and mines circa 6.4?
        Should i replace the front control arms ?
          Are there any modifications to the suspension?
            7.4 sounds a little high for stock, 6.4 sounds about right.
            I wouldn't suspect the front arms, they don't bend (alloy) and the balljoint should be fine for 200k. Sloppy FCABs could use a replacement.
              7.4 (+- 0.5) deg is what TIS calls for.
              BL92 are your top mounts clocked correctly? There's an arrow on them that should be pointing to the front of the car (assuming they're the stock parts).
                Thanks again everyone
                Yes, all stock, i reused the top mount, replaced upper and lower pads and yellow bearing insert
                Upon reinstallation, from memory, the top mount would only go in 1 way, as there is a locating pin and locating hole in the strut tower
                  That's true, but you could still have them swapped side to side. They should have an L and an R on them iirc. Remove those little pins for more negative camber, then get alignment.
                    Right. 6.9 is as close as mine will come with Vorshlag plates. It was about the same with fresh OEM top hats.
                    Old, not obsolete.
                      Being pedantic 7°40' is not 7.4 degrees. It's 7.66 degrees.
                        Just checked, mine is a RHD drive car so R is on Drivers and L is on Passenger
                        maybe i need new top hats ?
                          The smaller range of wheel lock is 7.4 deg
                            Did they ballast the cars? The BMW alignment specs I believe account for 180s lbs in both front seats which would change the alignment. Also, when was the last time the shop calibrated the laser heads? Was the lift level? Tires at hot PSI?
                            What I'm saying is I wouldn't worry about it. It is not off enough to make much of a difference. Most important is toe is within spec.
