Saleri is junk! Mine started to go out after only a few thousand miles. I just received a bmw pump to install. The way I see it now: the plastic impeller is supposed to flow better, it is lighter and it is better balanced. This also means less rotational mass, bearing will last much longer. Less mass, just like lighter pistons and lighter flywheel = more performance.
Why do i feel like trying a magnetti mirelli one this summer LOL
Because you like living life on the edge.
Usually cavitation is what destroys centrifugal pumps in industrial uses. Rarely does an impeller or end plate go bad. The shaft seal is what normally goes first.
