Instrument Cluster Repair
    Looking for a recommendation on where to send my cluster to get repaired. I've checked all fuses, tried the cluster reset and the cluster test and neither seem to get my gauges to move.
    Thinking about reaching out to https://www.bmwgm5.com. Just curious if anyone has used this service or has something else to recommend.
    02 M3 @128k.
    Thanks.
    I used these guys for my cluster repair last year. Good service and quick turnaround.
    If your BMW E46 has dead or fluttering gauges then this service is for you. We have repaired a lot of these with those issues. Also LED upgrade conversion is available. Send it to us for a fast reliable repair. Fits BMW E46 2000 2001 2002 2003 2004 2005 00 01 02 03 04 05
      This is becoming common, We need a DIY on this, I think it's the trickle charges causing the damage
      Guy here in Australia is doing them, 100% positive feedback, don't think he is gonna give away his secrets though
        https://www.ebay.com.au/itm/12578301...kqdkn3n3GUctmp
        Why do you suspect trickle charges?
          https://www.automotivecircuitsolutio...repair-service
          I reached out to them last month and he tells me they don't work on E46 clusters now. I replied, "Really, that's a pretty popular car, are you sure?" and got ghosted.
            trickle chargers, or any type of battery charger for that matter can cause ripple currents.
            /// 2004 SG/IR - Build Thread
              Are higher quality TC less of an issue?
                I believe so, I would be willing to bet the CTEK and NOCO TC's are very good. As long as the TC is doing its job, I don't think there should be any concern.
                It's probably the TC's that are "over-charging" the batteries that may cause the ripple current to actually overheat the battery or cause some transients to bother electronics.
                Also a rare situation, if you were to use a generator as the AC source with "dirty power", it would also probably cause more issues than using your home outlet.
                  Thanks
                    I've always wondered about the desulphation mode on trickle chargers. Some of them do it automatically and it raises the voltage all the way up to ~17V...
                      One can always disconnect the battery to run that mode.
                        I'm pretty sure that's how it's intended to be used. However, my lead acid CTEK charger seems to very briefly run through it on every startup.
                        I might just be misinterpreting the LEDs and noises though
                          That is surprising. They fixed mine the last week of March.
                          Old, not obsolete.
                            We do need a DIY on this.
                            Old, not obsolete.
                              There are some DIY out there, just look around for e46 instrument cluster repair in general, they're all about the same. I've repaired mine myself , I got the speedo motors and capacitors on e-bay or digi-key. If you get a used e46 cluster, just de-solder the e-prom chip and swap it over from your old to donor, is more straight forward than to edit the binary.
                              I m starting this thread with the hope that we can finally find a repair solution for this issue, my 2003 e46 325i instrument cluster suddenly stopped working for no reason, only the airbag and ABS light works, AC only blows hot air, both the exterior side mirrors are dead, apart from that...
