Originally posted by Alex
View Post
Csf radiator and bleeding
You looked down the tank with a hot engine running? Don't run the hot engine (or more than 10 minutes from cold engine) with tank cap opened, as the low P will cause the head to boil coolant around the EX valve seats, then created air pockets in the head and can lead to cracked head.Originally posted by Alex View Posthowever the past 2 days i have been seeing air in the system.
160K miles, it never leaked just wanted a refresh to prevent future issues, I just drove 1200 miles round trip up north with oem radiator and no cooling issues or loss of coolant! I suggest oem in your case if you want to keep oem hose set up!Originally posted by ac427 View Post
Thanks Alex. I am in a similar predicament to you but with the OEM radiator.
I think there must be some debris in the radiator.
How many miles had your car done when you swapped from the OEM to CSF radiator ?
