I’m about to throw the Turner swaybars on my car today or tomorrow and wanted to run this question by people (which may be a bad idea for my weekend..) about the necessity of reinforcement for those that run larger/stiffer bars. For those that have them installed, have you had any issues?
Sway Bar Reinforcement(s)-Thoughts!
[Karbonius] [MCS 2WNR] [Zionsville] [ [SPAL] [Ground Control] [Beisan] [Rogue Engineering] [Vorshlag] [Redish] [CMP] [Bimmerworld] [Kassel] [TTFS] [Apex] [TMS Sways] [Buildjournal] [Radium] [Ultimate Pedals] [OMP Seats/Harnesses] [UUC SSK] [Custom Cage] [Supersprint] [Carbontastic] [MEC CSL Diffuser] [Trackspec] [Street Faction] [Condor] [Hard Motorsports] [AiM] [Maintenance] [Ask me about products and exact weight of front end components]Tags: None
Originally posted by Fresh1179 View PostI’m about to throw the Turner swaybars on my car today or tomorrow and wanted to run this question by people (which may be a bad idea for my weekend..) about the necessity of reinforcement for those that run larger/stiffer bars. For those that have them installed, have you had any issues?
That said, if you're running very soft (as in, stock is 160 lb/in) springs and stiff sways with very sticky tires, yes, I'd do the reinforcement-- you'd be putting load on them it wasn't designed for.
I’m still trying to figure out to quote in this new configuration but thanks Obioban. I’m running some pretty stiff springs (sways being changed during installation of coil overs). Also, thank you for the 100k maintenance thread. Followed it to a T, with some performance mods and the car runs like new.
I think they're mostly a remnant of e36 thinking, where the failed easily and often.
I think I would run at least those brackets given that BMW felt the need to on the CSL, which has a relatively mild front sway bar compared to aftermarket options.
Seems to be rare on this chassis, but there are examples out there of the front sway bar mount failing. I wonder if the CSL front bracket (steel instead of aluminum) would sorta double as a reinforcement.
I think I would run at least those brackets given that BMW felt the need to on the CSL, which has a relatively mild front sway bar compared to aftermarket options.2006 ///M3 6MT Coupe Jet Black Track Car
Originally posted by Fresh1179 View PostI’m still trying to figure out to quote in this new configuration but thanks Obioban. I’m running some pretty stiff springs (sways being changed during installation of coil overs). Also, thank you for the 100k maintenance thread. Followed it to a T, with some performance mods and the car runs like new.
Would there be any issues with fitment of the bushings? I don’t know if the CSL bushings were a different size than the non-CSL models.
31356754336
Vs Stock:
CSL Sway Bars - My car is fitted with these mildly stiffer bars, clamped into place with Powerflex Purple poly sway bar bushes (fairly stiff, these do not give to “fingernail” pressure like the OEM bushes do), and my sled is suspended on PSS10s. I’ve had this combo for many trouble free years. This is the extent of my experience with non-stock bars, YMMV.
Weren't the issues not really with brackets breaking but the studs and the whole attachment point? I think that is what needed reinforcement rather than the bracket. I remember a few folks on old forum ripped theirs (don't remember who exactly - crookedcomie or moose or someone else tracking).Youtube DIYs and more
Also to add I'm running "flat ride" with 375/628 springs and Turner front bar on soft and it behaves well for canyons/autox/track. That said I do NOT run sticky tires, I'm there to have fun instead of chasing lap times, so in my case I prob don't need to worry about reinforcement. If you run 200tw or lower tire and track a tonne with full weight car, prob makes sense.
That said, I haven't seen kits specific for swaybar area, seen some for engine mounts. I think guys who ripped theirs on the other forum had to fabricate and weld some custom reinforcements.Youtube DIYs and more
The e39 M5 has Beast Brackets for the rear sway bar. On that platform the OEM brackets are prone to break so these are billet aluminum reinforced brackets. Not sure I've seen anything like it for the e46 M3.2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 288/280 Schrick Cams+DLC Followers | Lang Head | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 400/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | Turbo Toys V2 Hub | WPC Rod Bearings
I had one of the studs pull through the mount on my passenger side. I'm running TMS bars set to the middle, Eibach sport w/ Bilsteins, also some super hard bushings on the swaybar. Also sqaure PSS. I have one track day on it, but otherwise it's daily driven.
I made some reinforcement plates and it's been fine since.
I guess I should have expected it, just adding a data point.
Originally posted by mrgizmo04 View PostAlso to add I'm running "flat ride" with 375/628 springs and Turner front bar on soft and it behaves well for canyons/autox/track. That said I do NOT run sticky tires, I'm there to have fun instead of chasing lap times, so in my case I prob don't need to worry about reinforcement. If you run 200tw or lower tire and track a tonne with full weight car, prob makes sense.
That's still more than twice as stiff front springs as stock!
Originally posted by duracellttu View PostThe e39 M5 has Beast Brackets for the rear sway bar. On that platform the OEM brackets are prone to break so these are billet aluminum reinforced brackets. Not sure I've seen anything like it for the e46 M3.
Originally posted by Obioban View PostSome sways come with that-- E.g. the GC race front sway I'm running does:
