Originally posted by Slideways
View Post
Looking for clutch replacement DIY recommendations
Originally posted by Slideways View PostDon't shops just jack up the front of the engine a little, while it is still connected to the front subframe, to gain more access to the trans bolts? Removing the subframe with the trans mount disconnected seems very sketchy, even with the engine support bar.
TIS says to remove the intake manifold as well; otherwise, that carbon airbox might go crunch against the firewall.
I know this because...I cross threaded a bolt. What a nightmare! I've probably had more practice than most when I was trying to figure out the whole resetting the self-adjusting clutch mechanism process. God that fucking sucked...at least it was with a 5 speed. I was soooo close to buying a lift.
- Likes 3
Leave the subframe bolts in, just partially back them out and then lower the subframe. Of course, you would want to support the subframe. It makes the two lower block bolts much easier to get a socket on. There is a risk of cross threading those bolts, especially the driver's side, because the trans tunnel interferes just enough so that the socket isn't on straight. Then there is not enough room to thread the bolt in by hand unless you have little girl hands...lol
Just did this job a few weeks ago. The biggest challenge is the position of the bellhousing bolts and the available clearance. Ensure the clutch disc and friction plate are centered well, too; otherwise, the transmission input shaft splines will not insert. I recommend using the clutch alignment tool and double-checking alignment. The tool in my LuK clutch kit was plastic and was partially bent, so be mindful of that.
I changed my clutch yesterday, it was an all day affair ending at 1am. Besides the car having 124K miles and not knowing previous history, I was hoping to resolve intermittent pop-outs when releasing the clutch, it never pops out when in gear cleanly. Well that issue is not solved. Unfortunately I didn't replace detents, so either that's the issue or transmission itself. If anyone has seen this and knows what the problem is, please let me know 😐
