Have an interesting issue (that’s been beaten to death but can’t really find a solution) where ONLY when I have the AC on and I’m pulling into parking spot, turning the wheel hard, or slowing down to a light while coasting in neutral, the car’s RPM dips and then I have to either blip the gas to save the car from stalling, or it stalls. Happened much after I installed my airbox and Alpha-N tuned it. I reached out to the tuner and we tried raising the idle but that didn’t get much progress. Something about the engine being under load with the AC on is driving things haywire when pulling into an idle.
Couple notes:
- I cleaned my ICV well
- Car is manual swapped with the brown clutch switch (cruise control works)
- It’s fully flashed as a manual which the tuner did to make it as “factory of a manual” as possible
- Using an MSS54 DME with just the Alpha-N tune, haven’t done the MAP conversion
Any ideas?
Couple notes:
Any ideas?
