Originally posted by 6speedS54
Yeah, I feel it by the shifter stick, feels like it doesn’t travel as far as when it’s in.
Do you think with more effort moving the stick the gears will mesh deeper and wont' pop out, or it is locked up and couldn't push in deeper?
I would replace the balls/pins in the odd holes at upper right rear of the box. They create detent on the R, 1/2, 3/4 internal shift rods (ball or pin pushed on the rod groove), but if they are in bad shape then the detent became lock, prevents the rod to move far enough for the fork to engage the gears (actually the dogteeth to slider gear).
