S54 Header Design talk
    Right - that's what everyone says, was just curious after he scanned headers and ran it through any flow visualizations if anything even remotely popped up. Would be great to just see it as a visualization.
      Right, nothing to see. The number is so small you won't "see" anything. Put .119 vs .118 into a graph, see anything?
        Originally posted by 332 View Post
        Right, nothing to see. The number is so small you won't "see" anything. Put .00000119 vs .00000118 into a graph, see anything?
        Jesus Christ, I'm just asking for a visual if he had any done? It's not like I don't believe this to be the case, I'm just asking. Goodness gracious.
          Jesus Christ, I'm just asking for a visual? It's not like I don't believe this to be the case, I'm just asking. Goodness gracious.
          I don't know how else to say, the difference is so small. Their isn't a way to give you a visual, that I know of. Most people go with the standard tools of measurement. Back pressure, HP gain/loss, EGT, you wont find (see) anything significant. This horse is dead
            you probably mean a spike which are commonly used with non merge collectors that use parallel pipes and a formed merge rather than pipe merging at an angle
            Honestly, I just might be haha.
            2006 E46 M3 Interlagos Blue ZCP Slicktop "CS"
              So I decided to have a go at this... This is what I was able to come up with. I used the engine scan from this GIT, a proprietary E46 Chassis and carrier scan that the owner shared with me, and a bunch of AI.
              The primary length spread is 1.6mm with a 4 stage design so it looks fairly good for the first shot. The flanges are still from the Megan Racing header as takeover so those still need work. The ends are roughly the same as OEM, but with a 63,5mm pipe.
              What I still need to check is reinforcement plate fit. I only had an estimation that I placed on the chassis, which it clears.
              And I need to countercheck with the supersprint oversize section 1, ideally I want to make it mate to this...
                Ask and you shall receive - PM inbound.
                  Certainly looks the part, will those clear the headshields and what not on the top side?
                  Email to [email protected]
                    Unlikely. I don't use the factory heatshields above the headers, since my current headers have coating and thermal insulation. Any header that has a bend upward is likely incompatible with factory shielding.
                      Can you actually assemble and weld those? It looks like they are trapped together. I suppose if you're printing them, you may only need to weld on flanges.
                      2003.5 SG/Grey
                        You should be able to squeeze Bank on through bank 2, its just cylinder 6 goes around. I'm also still working on them. Generally they still have too many parts, which will make them expensive to manufacture.
                        I also need to get more detailed on the collector. I don't think you can get any 3in1 made from inconel off the shelf, which is what i want to make them out of.
                          Altaran how long are the primaries and what are the diameters?
                            Altaran you inspired me. I pointed Grok Bot at my CAD models for a few hours today and I've now got all clearances totally resolved (including *all* heat shields), 590 +/-1mm runners, secondaries within 10mm, single step at 290mm from 38mm ID to 42mm ID and an AI-designed first collector iteration. The bot is chugging on a full length 7-10 degreeish merge collector replacement now.
                            What a world.
                            In process progress updates:
                            Click image for larger version  Name:	Grok Header in-process.png Views:	0 Size:	232.1 KB ID:	615257
                            First iteration before corrections:
                            Click image for larger version  Name:	Grok v1 snapshot.png Views:	0 Size:	411.3 KB ID:	615251
                            Second iteration, including a collector:
                            Click image for larger version  Name:	Screenshot 2026-11-12 at 7.58.02 PM.png Views:	0 Size:	738.1 KB ID:	615256 Click image for larger version  Name:	Screenshot 2026-11-12 at 7.58.45 PM.png Views:	0 Size:	772.5 KB ID:	615255 Click image for larger version  Name:	Screenshot 2026-11-12 at 7.59.12 PM.png Views:	0 Size:	556.4 KB ID:	615254 Click image for larger version  Name:	Screenshot 2026-11-12 at 7.59.21 PM.png Views:	0 Size:	581.6 KB ID:	615253 Click image for larger version  Name:	Screenshot 2026-11-12 at 7.59.28 PM.png Views:	0 Size:	310.8 KB ID:	615250 Click image for larger version  Name:	Screenshot 2026-11-12 at 7.59.38 PM.png Views:	0 Size:	344.2 KB ID:	615249 Click image for larger version  Name:	Screenshot 2026-11-12 at 7.59.46 PM.png Views:	0 Size:	557.9 KB ID:	615252
                              What a world.
                              Are we getting....Bryson headers too now?
                              |06 6 Speed Vert - JB on Cinnamon|Beisan|ACL RB's|ST Sway Bar|3.91|AutoSolutions SSK|​Bi-LED|​TMS CSL Box|Megan headers|Mullet Tune|Bryson Air Inlet|​E86 Triangulation Brace|Bryson Fender Braces|​Dusan Rear X Brace and Topside​​|​OEM Section 1, 2, 3|200 Cell Cats|Bilstein B12|712 yellow tag|​
                                At this rate we’ll be testing the headers before the knuckles…
