S54 Header Design talk
    Originally posted by siamkazi View Post
    JEEEEZ ๐Ÿ”ฅ๐Ÿ”ฅ๐Ÿ”ฅ so these would eventually plug into a stock section 1?
    This version is intended to plug into an SSv1 section 1. If I can get packaging right, Iโ€™m going to swap the post-collector printed parts for a version with my own flange design that should seal better and be much easier to assemble than SS.
    The neck in the collector goes down to stock pipe diameter, so itโ€™s super easy to change that and make these 100% OEM compatible without messing with the headers themselves. Tried to make it intentionally flexible.
    โ€˜02 332iT / 6 | โ€˜70 Jaguar XJ6 electric conversion
      That's insane. Any way to incorporate an EGT bung for those of us who are using the bungs in our current headers? (i'm on megans right now).
      |06 6 Speed Vert - JB on Cinnamon|Beisan|ACL RB's|ST Sway Bar|3.91|AutoSolutions SSK|โ€‹Bi-LED|โ€‹TMS CSL Box|Megan headers|Mullet Tune|Bryson Air Inlet|โ€‹E86 Triangulation Brace|Bryson Fender Braces|โ€‹Dusan Rear X Brace and Topsideโ€‹โ€‹|โ€‹OEM Section 1, 2, 3|200 Cell Cats|Bilstein B12|712 yellow tag|โ€‹
        Honestly probably not - itโ€™s super tight down there and getting one wideband bung alone alongside the stock narrow bands is gonna be tough.
          makes sense, when it's ready to buy, i'll reach out to see the best options. Nonetheless, i'm definitely in, incredibly cool stuff going on here!
            you guys are so damn cool
              My SS havenโ€™t even been heat cycled! George, if I can get you my vehicle, you could use it as a mule, itโ€™s still in Houston and Iโ€™m in CA these daysโ€ฆ
                Man, I'm slacking, been at the track and just getting caught up. I have B1 printed and started B2 before leaving. I'll finish B2 in the next couple days, I think its something like 25hrs on the printer now.
                This one had a tube fail...
                Reprinted and still failed, but got far enough should be fine for mockup.
                Email to [email protected]
                  Her life is in your hands now George Hill
                  โ€‹
                  Click image for larger version  Name:	image.png Views:	0 Size:	69.0 KB ID:	616518โ€‹
                  Appreciate the offer fattycharged, I have a mock up chassis here with a block and head, I can throw that together pretty easy so no need for a complete car.
                    Wow lots going on in here. Awesome. I'm in work crunch mode until Dec 15 but if anyone wants me to test fit something on an assembled car my E36 is still sitting with no headers installed. Can also print whatever files are needed locally.
                      Files are in your Gmail inbox.
                        Hey team! I'd love to try and print these headers and test fit on my E46 M3 if anyone is willing to provide the Fusion360 files (.f3d) or .step files. Thanks and really interesting work!
                          Does your car already have headers removed and do you have a 3D scanner? That would make you a candidate ๐Ÿ˜Š Ideally we validate fitment with 3D scans so we can make final tweaks to where the outlets land - Iโ€™m sure theyโ€™re not 100%
                            Hey! No, the headers are not removed from my car and yes, I do have a 3d scanner (an older Einstar).
                              Awesome got them. I'll start printing them today.
                                You suuure you want to remove your headers to test fit plastic ones? Ha
                                There might also be a v2 to test thatโ€™s more likely to land in the right spot. And are you running a factory or supersprint section 1?
