S54 Header Design talk
    Originally posted by 332 View Post
    euro headers vs SS https://www.youtube.com/watch?v=Sszs6NybJ-4 I'd rather have something lighter.
    Close to impossible to find something lighter than CSL headers or even Euro headers
    One is better off finding a used set of either if the goal is lightweight.
      I always recommend to have a strong cup of coffee if you're trying to save some weight before a track day 😁
        I finally managed the 3D Printer to work, lesson learned is to not use cheap material, even if its only a mockup. This will probably take another week until its done.
        Some Pictures from printing:
ID:	616771Click image for larger version
ID:	616772Click image for larger version
          I have a bambu h2s and prusa core one if printing help is needed
            So it makes more sense to pay thousands of dollars to save a couple pounds?
              This is a flawed comparison, and I don't think it's right to conclude that euro headers are as good/better than SS. On a setup like this one where it's entirely stock other than the headers, the stock intake is a restriction point. IIRC there are several comparisons in the dyno thread show that the SS outperforms euro on cars with CSL intakes and cams. It would be fine for him to claim that there's no point in getting SS if you're planning on keeping everything else stock, but I think his claim that euro > SS on more serious builds is dumb for a tuner.
              Yes and no. Superprint primary diameters are sized for an engine making a lot more power than stock (which is what you are also saying). CSA on the second half the primary is roughly 40% bigger. Based on what I have seen and how the software I have used calculates: I wouldn't go that big unless I had bigger cams. As far as I have seen Supersprint doesn't advertise them as application specific, just better. Also on the supersprint design as I have pointed out several times: The primary lengths are all over the place, not even in the ballpark of equal to a degree that represents a huge difference in what RPM each primary is tuned for. It's also a formed collector which is a cheap choice for how expensive the headers are.
              FWIW primary diameter is sized to control air speed in the exhaust. CScavenging effects increase with air speed but it has to be balanced against back pressure increasing as your try to cram more air through the system. When primaries get too big scavenging suffers. Depending on how it plays out that can rob power from the whole RPM range, not just the bottom end. CSA in the primaries should be tuned to the amount of exhaust gas and the target velocities across the rev range.
              TLDR headers are application specific. Most of us want a fat torque curve which is the same design goal the OEM had. We are also all making more power than a totally stock tune, USDM catted car so its probably appropriate to modestly size up primaries.
              Also I posted this earlier but it's useful for perspective.
                Decided to design some headers myself (cylinders 4,5,6). I'll print out of PLA on my Bambu H2S for test fit and then out of metal for engine dyno testing.
                  Do these provide at least 50+ hp and weigh 2 grams? Deal breaker if not.
                  |06 6 Speed Vert - JB on Cinnamon|Beisan|ACL RB's|ST Sway Bar|3.91|AutoSolutions SSK|​Bi-LED|​TMS CSL Box|Megan headers|Mullet Tune|Bryson Air Inlet|​E86 Triangulation Brace|Bryson Fender Braces|​Dusan Rear X Brace and Topside​​|​OEM Section 1, 2, 3|200 Cell Cats|Bilstein B12|712 yellow tag|​
                    If I could keep each "bank" under 8lbs (currently at 7.09 with the material I selected and wall thickness) and not lose torque over the RPM range, I think that's a win, for me. Again, this is just a fun engineering exercise.
                      I have over 6k invested in my exhaust, rather have the lightest possible parts everywhere I can. "if" we could produce the lightest and highest hp headers on the market, why is that a bad thing? ANYONE willing to make an equal length, stepped, 6 to 1 header
                        Click image for larger version  Name:	image.png Views:	3 Size:	520.2 KB ID:	616780​
                        Does anyone have actual measurements of the exhaust port inside diameters? The image above indicates an ID of 38.5 mm.
                        I'm trying to establish the nominal diameter and variation across all six ports. Has anyone physically measured multiple ports to determine an average diameter and standard deviation? For example, would 38.0 ± 1.0 mm be a reasonable assumption, or is there measured data available?
                        I'm getting ready to 3D print my prototype headers and want to ensure the most accurate representation possible.
                        I also spoke with VAC Motorsports and am attempting to drop off my printed prototype (PLA) for their review and feedback. We're also going to explore whether an engine dyno test might be possible.
                          The image above taken from a scan is almost certainly better than a physical measurement. I used 38mm for mine for what it’s worth, seemed to land pretty appropriately on my scan which had all six partial exhaust ports.
                            yeah I have measured the whole port. you can see a surfaces model of the port geometry in the first post. port to port is very consistent. I'm out of the house right now but I can get the min csa and csa at the valve throat too if that's something you want.
                              Perfect. My model is parametric so it's easy to adjust dimensions. I'll start the print Sunday 29Nov26. It will be two pieces, PLA, 12 hours on Bambu H2s.
                                one easy design feature I think would be positive in everyone's parts: oversize the primary diameter on the port exit by about 1.5mm and then taper back down at a shallow angle. the exhaust gases won't "see" that area change and it will cover up to .75mm of misalignment of the flange on the port.
                                Also question for everyone here who has installed and removed a bunch of headers: Flange style? I really dislike the recessed but style on the Megan headers and don't love the OEM stamped design. A thicker flat plate still works with the shorter OEM head studs and makes tool access a lot easier. Does anyone have a different opinion?
