S54 Header Design talk
    The issue is weld/torch access on bank 1. I took a few pictures. Maybe someone else better at tig can get in there but I know that's too crowded for me. Its possible we can spread things out just a little bit where needed? The sharpie marks are 350mm from the choke on the merge. Imagine a needing to get a torch and filler into place on the full circular cross section of that joint.
      I've got way more room in mine - there's space to land welds in there for sure.
Name:	Screenshot 2026-11-14 at 1.56.42 PM.png
Name:	Screenshot 2026-11-14 at 1.56.56 PM.png
        Nice okay- Your layout seems very doable for welding.
        What's the current spacing between primaries on the merge entrance? I'm going to model a quick mesh for a merge collector as reference that should drop in easily.
          You should have it in the fusion link but they’re all 45mm OD 1.5mm wall and tangent to each other along the same axis at the start of the collector
            Converging-diverging collector iteration is complete now that Grok got to it's Monday assignment. Acoustic length of this setup is unfortunately still a bit long at 696mm from valve to adjacent merge point and they're 13.75* included angle. Diverge is 4* included so I'm going to make one more iteration that steepens that to 7-10 degrees and shortens the collector in the case it needs to move around for packaging a bend.
            Click image for larger version  Name:	v4c C-D collector model.png Views:	0 Size:	138.2 KB ID:	615640
            Click image for larger version  Name:	v4c C-D collector.png Views:	0 Size:	194.3 KB ID:	615641 Click image for larger version  Name:	v4c C-D collector sections.png Views:	0 Size:	164.7 KB ID:	615642
              Little update from my side, thanks to Bry5on for sharing his files. I made an adjustment to my design so they have the same end location as V1 headers, so they can be used with existing section 1. I have little interest in making a custom section one, especially since the SS works.
              The previous design had the OEM end locations. I will keep a version of that with future modifications, in case people with a more stock engine will want an equal length header.
              I played around with changing to a non stepped design with a larger pipe from the beginning. Simulations yielded a slightly higher peak gain, but it was at 8300 an upwards. My Valvetrain can take 9k, but its not that interesting since from 6k to 7k there would be a slight loss compared to this 4-Step design. Also it would require shortening primaries to 480mm and AI did not find a proper solution to pack it in the existing space with my equal length constraints (on 2mm deviation allowed beween primaries or secondaries)
              I still don't think I'm 100% where I want to be but I'm making progress and with winter I'm also not in a hurry.
Name:	V2.0 Krümmer.png
                This is awesome.
                2003.5 SG/Grey
                  Real time updates, now with shorter converging-diverging collectors and flanges
                  Click image for larger version  Name:	v4d C-D collector.png Views:	0 Size:	167.9 KB ID:	615661
                  Click image for larger version  Name:	v4d C-D collector model.png Views:	0 Size:	136.5 KB ID:	615660
                  Click image for larger version  Name:	Screenshot 2026-11-16 at 6.39.09 PM.png Views:	0 Size:	870.5 KB ID:	615659 Click image for larger version  Name:	Screenshot 2026-11-16 at 6.39.44 PM.png Views:	0 Size:	515.4 KB ID:	615658 Click image for larger version  Name:	Screenshot 2026-11-16 at 6.40.07 PM.png Views:	0 Size:	514.8 KB ID:	615657
Name:	Screenshot 2026-11-16 at 6.49.54 PM.png
                    Amazing work Gents.
                      Alright I think I’m done with the headers and it’s time to test print. They’re sectioned to fit in the 3D printer and include clocking features at every joint.
                      George Hill has volunteered to occupy his printer for a while to get these going and I’ll probably do the same, even though I don’t have a handy test vehicle.
Name:	Screenshot 2026-11-17 at 6.19.56 PM.png
Name:	Screenshot 2026-11-17 at 6.19.48 PM.png
                        Nice! What's the ideal (or hopeful) results with these once fitted? (all things being equal and no left field issues pop up).
                          Better sound, more even AFRs between cylinders, maybe a torque bump around 3k and hopefully a hair more power around 6 or 7k. It will likely lose a little in between but that’s a good price to pay for even AFR across cylinders I think.
                            ... and used V1s getting cheaper, overnight.
                              So I am also done for the time being designing mine - at least for the time being.
                              At the End, I made 2 Models for 3 header options:
                              - 0,7mm Inconel 625 4-Step-header with 63,5mm secondaries P&P V1 fit, for heavily modified engines with ported headers
                              - 1.5mm Stainless Steel, same as above, should be more cost effective, but a minor power loss compared to 625 due to the lower ID of the piping. Greater OD to keep the same ID is not fitting the available space.
                              - 1,5mm Stainless Steel 4-Step-headers with 60mm secondaries P&P fit OEM Section one, simulated against stock engines with CSL cams and not ported heads
                              Next step here is also 3D printing. My buddy is dropping a printer off here on the weekend, then I will start printing a mock-up (which will probably take a long time...)
                              After that, the plan is to test fit the mockup in the car (still need to get a V1 Section 1 from somewhere to test position and fit). If all fits, the mockup will be used to build a jig and I will start ordering pipes and other components.
                                This is all so awesome. Not selling my V1s though as the price difference will be like going backwards financially LOL
