Fan Clutch Info
    Fan Clutch Info
    First, I want to say I am happy for Efan users. You can tweak and have closed loop control over the engine temps, you have better access for working on the car, less parasitic loss, and no fan blades to smash into your hood.
    If you are unfamiliar with how a clutch fan works here it is:
    TL;DR: A fan clutch is a device that responds to the air temperature coming through the radiator. It uses a fluid coupling and a bi-metallic switch to engage or disengage the engine fan within a specific temperature range. It’s also designed to limit fan speed at higher RPMs. This part is considered unserviceable and is responsible for providing airflow when the vehicle is at rest or moving at lower speeds. When it fails, it can either stay disengaged (causing overheating) or remain fully engaged (causing excessive fan noise and drag).
    Now, for those who would like to maintain an entirely OE-style cooling system, I’ve been collecting information. For most, there are no issues with using fully OE components. However, as parts quality continues to decline and the availability of the OE parts that many enthusiasts originally used to baseline their cars diminishes and as dealer pricing becomes less reasonable it’s becoming more challenging to keep the system as it was intended. I think it is important or getting more important to scrutinize and document what works and what doesn't work for parts. I think it is also important to document items going NLA to avoid good used parts getting thrown out or to help stockpile NOS parts.
    Something like a clutch fan, I consider a fairly mission critical part that's important can pop up on a 90+ degree day where you are forced to idle and crawl through traffic, or when you come off track and are waiting on grid.
    With that being said the known quantity here that has served people well for many years:
    __________________________________________________ __________________________________
    OE E46 M3 Fan Clutch:
    BMW Part Number: 11527831619
    OE (Behr) Part Number: 8MV 376 733-001
    Mahle: CFC75000P​ (behr and mahle got bought or merged in 2010 https://workshop-heroes.mahle.com/en...-becomes-mahle)
    If you source just a Behr/mahle replacement without the BMW Sticker this is probably what you will get
    As Anri has shared here: https://nam3forum.com/forums/forum/m...182#post231182
    "Behr fan clutch will engage at around ~93-98C and will shut around at ~85-88.."
    This makes sense as it aligns with what the coolant gauge reads for that fan clutch engagement temperatures.
    How trustworthy are the OEM oil temp & coolant gauges? I was at the track yesterday, and saw the oil temp gauge pegged just beyond the "dot" between 210 and 300. Is this safe?
    "Coolant temp gauge reads straight up and down from 85-95*C, it starts to move right at 96*C and when it's getting into the red zone its about 107*C (ish).
    __________________________________________________ __________________________________________________ _________
    With the stock Behr/Mahle setup established as the baseline, the next logical step is to look at how the community has experimented with other clutches. For those with lower temp thermostats or in very hot climates
    Below is a summary of community findings:
    Lets say you want alternatives for a more aggressive clutch fan here are the options:
    All the options stem back to this BMW number. 11527505302 which was considered as a tropical fan clutch to European E36s but was the standard fan clutch for E36 M3s USA.
    This first comes back to the HPF and AA upgraded fan clutch.
    https://store.activeautowerke.com/products/e36-e46-sport-fan-clutch-323-325-328-330-m3​
    Note the very different bi metallic spring design. The reviews are very poor on FCPEuro as people are complaining they are always on so maybe they are that aggressive or it is quality thing and they're bad out of the box. I have not ordered one myself to confirm, but the attached facebook user seemed very pleased.
    I did have an incident where fan hit my crumbling shroud and exploded. My friend gave me free replacement clutch fan and it had an identical bi metallic spring design. It was from a E39 525i. It does have a very aggressive lock up, have used it in the Houston summer no issues. I have also done quite a few track events with it.
    SACHS 2100 010 031 (E36 M3 Fan Clutch – Confirmed by Anri)
    Credit where it’s due — this section of information originates from Anri of Euro Classic Motors (SoCal), whose deep technical posts on NAM3Forum have helped clarify how the E36 M3 fan clutch interacts with lower-temperature thermostats.
    August 7, 2024 - UPDATE 7 - First oil change after driving 5,000 miles: no oil lost Page 17 has the full update - Oil change, 70C Degree thermostat install - The 70C degree thermostat is wild: totally changed the torque curve of the car: no more heat soak! - Also did the front brake lines again with the same Bimmerworld
    Tricks how to improve the system in every area is something I usually
    don't like to share online but in the name to help the community here we go.
    The Fan clutch I use is from E36M3 which fits all M50 engine family
    and the brand is Sachs part number 11 52 7 505 302. (I have another
    more aggressive custom option but will shorten the life span of the water pump
    by a bit but that is for heavy duty applications).
    The Sachs engages right above the thermostat means the second the
    T stat opens at 80C and pushes the water circle inline the fan clutch engages
    immediately and keeps the engine from heat soaking and will shut down
    aprox ~68C, and the cycle continues.
    It's recommended as a great pairing with his 70C Thermostat, if you are unfamiliar with that here is the thread:
    Gents, I added 75° options as well for Cold states. The 70°-75° are all tested and it works great and no Check engine Light is triggered so no need for adjustments in the ECU. After many tests here is the data from the OEM spec: At 80° Opens 1mm at 80°, 83°~3mm at 85° is fully open Completely Closed at 77° +/-1° ​70°. At
    To take full advantages from the 70C Sachs Fan clutch is a Must !!!
    At the time of this post, Sachs had already marked the 031 as to be discontinued, though stock remained in circulation through various resellers and NOS parts.
    Based on both catalog data and owner reports, it’s a direct-fit part on S54 cars and provides noticeably stronger low-speed engagement without affecting high-RPM behavior.
    Tropical Sachs E36 M3 Fan Clutch 2100 010 032
    While researching the 031 fan clutch, I discovered that Sachs also produced a tropical variant — the 2100 010 032. This was a new finding that hadn’t previously been discussed in the E46 community.
    This “tropical” calibration is a Sachs tradition seen on several older models (E28, E32, Mercedes W123/W124, etc.), where the clutch is tuned to engage at a lower air temperature for markets in hotter climates. These are genuine Sachs parts, not aftermarket rebrands, and are identified in the catalog as “for tropical climate zones.” It's also lighter interestingly enough. ​
    https://aftermarket.zf.com/en/catalo...amp;country=ES
    According to Sachs this is for 11521737489 but it doesn't directly correlate with a vehicle on RealOEM.
    However, it does say it is a 75 Celsius fan clutch on RealOEM so I ordered one from Rock Auto to test. I will report findings once I test it. The 032 is also planned to be discontinued so we are left only with older stock.
    https://www.realoem.com/bmw/enUS/partxref?q=11521737489​
    Build Thread:
    Had an issues with attached images, I think fixed now. Verified on my mobile
    Build Thread:
      "When it fails, it can either stay disengaged (causing overheating) or remain fully engaged (causing excessive fan noise and drag)."
      A good working efan should prevent the overheat issue even with a disengaged clutch fan.
      I wonder if the stock M3 cfan would engage at lower T than the generic cfan for the non-M cars. These cfans are not totally enaged (locked up) nor completely disengaged. They are always partially engaged proportional to the T on the bi-metal element.
        Some great info here brother! Do you have a link for the SACHs fan as I would love to order one to try when our weather gets extremely HOT again
          Interesting cause i live here in Australia
          I installed the 11527831619 no issues
          I will check my old 1 and see what part number is on that
            As stated, the Sachs are being discontinued unfortunately. So finding a distributor that still has it or NOS on Ebay is the way to go with the Sachs part number.
            I believe I might have bought the last one on RockAuto. https://www.rockauto.com/en/moreinfo...t=6812&jsn=472
            Build Thread:
              Bimmerworld might actually be selling 11521737489.
              So while this number doesn't directly tie to anything in RealOEM. However, on various different retailers it says its for 5-6-7 series. Which would tie it to 11527502804, which is a 92C version.
              Click image for larger version  Name:	image.png Views:	0 Size:	240.1 KB ID:	327677https://www.bimmerworld.com/Fan-Clut...527502804.html
              Build Thread:
                Any updates on this on which is the right part to order as an upgrade from oe/oem?
                  I have been using this guy 2100 010 032
                  Build Thread:
                    Thanks brother. What's the best place to buy it from?
                      My car was diagnosed as having a bad fan clutch. Car was overheating in stop and go traffic in 90+F temps in central Florida. I ordered a new OE fan clutch made by Mahle-Behr, installed that and a new fan blade and I'm still having the same overheating issues in traffic. Now, I'm being told that sometimes these other "OE" manufacturers aren't as good and the shop is recommending a Genuine BMW OEM fan clutch. I'm reluctant to spend almost $400 for something that may or may not actually fix the issue by going from an the first/original fan clutch to an OE and back to an Genuine OEM fan clutch. Do you have any recommendations for my situation? Thanks in advance!
                      /// 2005 Silbergrau M3 · Coupe · 6spd · ZPP · Eibach Pro Street S Coilovers · Sportline CS16 CSL Replica Wheels · PS4S 245/275
                        I replaced my original leaking fan clutch with a Mahle-Behr part from FCP and noticed an improvement in temps. Now, some say the SACHS is the better part. I will also say, I originally installed my new fan backwards on the new clutch! A forum member caught it in a photo I posted, so, are you sure your fan is installed correctly?
                          If the dealer is still supplying original equipment good quality fan clutches, I would say that would be the way to go. Unfortunately I cannot say what they are currently supplying, hoping someone else can. I think that'd be a great data point.
                          Build Thread:
                            How old is the radiator?
                              I'm pretty sure...I didn't think I could put it on the wrong way, but I guess anything is possible.
