E46 M3 Base vs ZCP Conundrum
    Wow that reupholstered M-texture interior looks amazing. Mind sharing what something like that costs? Looks like you built the car that you wanted
      It ended up being north of $11K as many of the existing parts weren't able to reused given the entire interior was in grey. I ended up getting a new headliner and OEM A-pillars to correct errors made by another upholstery shop, who used the wrong material as well as crazy glue in their install 🙄
      2002 TiAg/M-Texture
        my dreams are now shattered lol.
          Can confirm, have seen this interior in person. I was jealous.
            If you already have a black interior, you could get your seats and door cards reupholstered with the M-texture fabric at a more reasonable price point:
            Reproduction of E46 M3 and E39 M5 "M Texture" fabricThis fabric is extremely high quality meeting all ISO safety and quality standards for UV resistance, fire protection and more It includes the perforated square Alcantara layer adhered over the top backing fabric and a foam layer underneath, just like OE A faithful reproduction of the original E46 M3 and E39 M5 "M Texture" material ( E46 M3 F2AT and E39 M5 F2 interiors BMW part number 51922698028 ) Now available by the footInternational shipping rates will calculate at checkout The width of the material is 58"Buying one foot gives you 12" x 58"Buying three feet gives you 36" x 58" Orders will ship as one continuous pieceie. if you order 6 feet you will receive a single segment which is 6 feet long and 58" tall For those who use metricThe width of the material is 1.47 metersBuying 1 foot gives you .30 meter x 1.47 metersBuying 3 feet gives you .91 meter x 1.47 meters Ships from the US and arrives to most locations within 5-6 days after the order is placed!
            My refresh was costly due to the fact that the seats, carpet, and door cards all had be to replaced given the plastic bits were all grey and couldn't readily be refinished.
            2002 TiAg/M-Texture
              Originally posted by xansabi View Post
              Sorry if this is a stupid question, what are the main differences between base and ZCP steering column?
              The ZCP got the steering rack from the CSL. It’s a tighter ratio of 14.5:1 vs.15.4:1. So it’s a sportier less full turns lock-to-lock. But also not as boosted, the internal spring valve isn’t as soft. So again, sportier. This is the one BMW M used in the CSL so it’s a performance feel and reaction. But nothing obnoxious by any means. *I see you added a ZF “yellow tag .712” 14.5:1 ratio rack so you now have the same “ratio”.
              Since you have the early MK20 you’ll want to swap in a MK60 to code for the 14.5 rack. Otherwise you’ll find it triggering DSC in quicker turns early. With MK60 you’ll then be able to also code for “M-Track Mode”. That allows you to have some ~20% more slip of the DSC before it intervenes. M-Track is a steering wheel control on ZCPs. Non-ZCPs use the DSC button on first push to activate. And a second hold of button to turn DSC off like it usually functions.
              If you were to later decide to add the CSL brakes that are larger fronts (cross-drilled floating aluminum hats) and larger rear caliper piston. The MK60 again has a very easy check box to click to code for the different CSL/ZCP brake bias also.
