Valve Adjustment Below Spec
    Picked up a kit locally , they are all there, just jumbled up
    Does anyone know if i should re-buy this kit to make 2 kits, or is there another kit with different sizes?
    With the entire exhaust over spec, i am guessing i need a lot of shims ?
    You can buy pack of 5 refills for each size. Certain sizes are used more than others.
      You can buy individual BMW shims of any size you want for $2 a piece from any online parts retailer, like FCP euro. I buy a bunch of several sizes before I adjust, use the ones I need once I'm in there, send the rest back for refund unopened. This process is made a lot easier if the last time you did an adjustment you took each shim in your car out and measured it, and put it in a spreadsheet. Then the next time you need to do an adjustment, you just need to order a size above and a size below each shim that's currently in there, and you're guaranteed to be covered without having to order a bunch of every size. You only have to do the tedious process of measuring each shim once, and it makes all future adjustments easier
      Part numbers for all the shim sizes here: https://www.realoem.com/bmw/enUS/sho...06#11347832287
        Awesome, thank you for the help
          I bought 3 of those Viseco kits when I swapped in new cams and followers... And also got a few shims of a certain size from the local dealer... So if you ever need one of those really big or really thin shims I'm your guy :P
          Regards
            Thanks again
            So i just measured all mine! Lowest was 2.21 and highest was 2.29. Any opinions on wear judging by the sizes? I managed to do some swapping around, ie using a 2.28 in place of the 2.21 etc. I may need 1 more 2.32 unless i can do some more switching around
              Thanks again
              It's kinda hard to swap around since the 0.04mm step in the shims is pretty close to the 2 thou range (about 1.5 thou). So you kind of need one particular size or not. Even with recycling old ones into different locations becomes a bit of a pain I found as they'd all be pretty close to the nominal size.
              2 Wiseco sets was enough for me but there are heaps of sizes way off that I'll never use. If you can be them individually reasonably priced do that although you'll need an idea of where you are in the range first. 2.2mm to 2.3mm was about where mine all are from memory.
                In my experience 2.40mm, 2.44mm, 2.48mm, and 2.52mm are the most commonly used. I got two wiseco kits then a 5pk of each of the above.
