Originally posted by BL92
Valve Adjustment Below Spec
Originally posted by BL92 View PostPicked up a kit locally , they are all there, just jumbled up
Does anyone know if i should re-buy this kit to make 2 kits, or is there another kit with different sizes?
With the entire exhaust over spec, i am guessing i need a lot of shims ?
Part numbers for all the shim sizes here: https://www.realoem.com/bmw/enUS/sho...06#11347832287
Thanks again
So i just measured all mine! Lowest was 2.21 and highest was 2.29. Any opinions on wear judging by the sizes? I managed to do some swapping around, ie using a 2.28 in place of the 2.21 etc. I may need 1 more 2.32 unless i can do some more switching aroundLast edited by BL92; 02-15-2025, 03:45 PM.
2 Wiseco sets was enough for me but there are heaps of sizes way off that I'll never use. If you can be them individually reasonably priced do that although you'll need an idea of where you are in the range first. 2.2mm to 2.3mm was about where mine all are from memory.
