All Things @parteeracing
    "Sorry hun, the kitchen remodel will have to wait..."
Name:	Screenshot 2025-12-16 103848.png
    Damn straight...
      I assume the 400whp on that stroker was with a CSL style intake since he mentioned MAP sensor.
        There's a full on discussion with Chris from Partee in the other thread, he dives into the details of the strokers etc.
        hello, i am new to this forum. i am looking for a set of ported throttle bodies just in the process of rebuilding my s54. i put je pistons, stage 3 lang racing cylinder head, csl turner intake. is it worth it to bigger throttle bodies in?
          You can't race a Kitchen, but you can cook in a racecar.
          E92 M3, 6MT
          Head​ of Engineering and Design
          ParteeRacing.com​​
            https://nam3forum.com/forums/forum/m...ge4#post330269
            Great stuff in there, figured it deserved its own topic.
              Ship to Australia ? we got bare bones here
                Yeah! Absolutely. We have a 4.6L S65 Stroker going to Malaysia in a week. Aus is just another step down the road from there.
                E92 M3, 6MT
                ParteeRacing.com​​
                  Agreed! I was feeling guilty for how thoroughly I threadjacked that post.
                  Those are Swamp Thing and The Clapper!
                  The sedan is Jimmy Roy’s car- he’s one of my favorite clients of all time. He came and spent a week with us in November and was a riot! At one point he started razzing Peter and by the time he was done I was in tears from laughter.
                  In the video above, he had our original HO S62 design from years ago, but we have refined the process and our product line has increased, so his car is with us now for a no stone unturned type of build /and/ a new HO S62 build as they are landing around 475 wheel horsepower now instead of 500 brake.
                  The Wagon is John’s car- he’s has two nearly identical E39 wagons, The clapper, as seen in the video has significant rust from its Wisconsin life, and the other is immaculate, but still has the original drivetrain. His plan is to get The Clapper running perfectly, then swap everything from The Clapper to the other chassis so as to minimize it’s downtime, because it’s his favorite car. John has been fighting drivability issues for years now, and finally sent The Clapper to us so that we could sort it. Very quickly we found some DME hardware related issues, and are now getting him sorted.
                  E92 M3, 6MT
                  ParteeRacing.com​​
                    Sounds amazing! My dream spec e46 m3 would be Partee s62 swapped.
                      Jeesh, you know how when you know something is going to be really expensive... so you brace yourself... you're like 'whatever I think it is I should probably double it'.... and then you go look, and the price still shocks you?
                      That was me checking out how much a stroker motor costs.
                      I still want one.
                      Stroker motor + 7 lbs of boost = IDK but it's gotta be fun
                      2004 Dinan S3-R M3
                      2023 X3M Competition
                        That Club build doesn't even include the dry sump setup, but a boy can dream.
                            I still want one.
                            I know the build prices are high; parts are expensive- they make up the vast majority of the cost, and quality work takes a lot of time. The crank and rods alone for the S54 Stroker are nearly $11,000. There are other cheaper crank and rod options, but they are not as good as Arrow Precision. Then Schrick cams, their followers, which MUST be used with their cams, and valve springs/retainers are another $8700. Nearly $19,000 in parts right off the top. That doesn't include the cost of the timing kit, all the gaskets, seals, bearings, labor, or even the custom Partee spec extreme tolerance pistons. We do not build a ton of profit into our engine builds; we exclusively use the best parts you can buy, and they add up FAST.
                            As I said above, part prices are through the roof. Our cost for the Daily pump and oil pan setup is approximately $9000. The good news is that we have club-race motors that have been in race cars since 2017, getting their teeth kicked in by their drivers weekend after weekend without ever having an issue. It is a robust and potent engine.
                            E92 M3, 6MT
                            ParteeRacing.com​​
                              I still want one.
                              If you think an S54 stroker is bad...price a Judd engine.
