Replacing E46 Sideview Mirror Glass
    DIY: Replacing E46 Sideview Mirror Glass
    Original Author Credit - Cooter
    From - M3Forum
    Dino's Add-on - This DIY is more geared towards production date cars up to 07/2004. For later models it's quite a lot simpler. Tilt the glass all the way forward so you can get your fingers behind it, apply even pressure towards you and pop the glass out. You won't need the wire extensions for later model cars. Connect the wires to the correct pins, then simply line up the tabs behind the glass, apply even pressure, and snap it into place. Enjoy your new mirror!
    A lot of M3 owners have experienced the dreaded "rusting" that begins to spread throughout the sideview mirror glass. Here's a quick DIY to show you how easy it is to replace it yourself.
    For this DIY, I replaced my driver's side glass. First, an example of the "rust" that spreads underneath the glass (top-right of the picture - pardon the dust, pollen season has officially begun):
    Click image for larger version  Name:	1.jpg Views:	0 Size:	22.8 KB ID:	3655
    First thing to do is to tilt the mirror up, which will expose a small tab underneath the mirror, circled in red:
    Click image for larger version  Name:	2.jpg Views:	0 Size:	29.2 KB ID:	3656
    Take a small screwdriver, and place it in the hole. For the driver's side, I pushed the tab to the right - towards the car, which didn't take much pressure at all, later model cars the glass just pops out:
    Click image for larger version  Name:	3.jpg Views:	0 Size:	30.5 KB ID:	3657
    This will unlock the retention clips that hold the mirror in place. After you've done this, start to slowly pull the mirror out of it's housing. You'll hear the adhesive begin to pull away as seen here:
    Click image for larger version  Name:	4.jpg Views:	0 Size:	25.0 KB ID:	3658
    My new mirror is a new version, which doesn't have an adhesive back and the electrical contacts have been moved to the other side:
    Click image for larger version  Name:	5.jpg Views:	0 Size:	29.2 KB ID:	3659
    The new mirror will come with an extension cable assembly that will allow you to plug into the existing cable, and move the cable to the other side of the mirror (Wires may need to be purchased separately double check before purchasing):
    Click image for larger version  Name:	6.jpg Views:	0 Size:	21.2 KB ID:	3660
    Click image for larger version  Name:	7.jpg Views:	0 Size:	33.2 KB ID:	3661
    After you've connected it, simply align the mirror in place with the clips and push into place. That's it, enjoy your rust-free mirror!
    Click image for larger version  Name:	8.jpg Views:	0 Size:	36.9 KB ID:	3662
    Great and easy DIY. I did this to my car but used the euro glass
      Pictures don't show up for me, but I do remember the original DIY.
      Also worth noting that on later build cars, they changed the mechanism. The glass just pops out.
        Correct, I should have added that bit for later cars to not cause any confusion. I have the PDF, when I get home I will update the post with the PDF for people who work better with pictures.
          This a great. Thanks!
            Pictures should now be working for everyone. I also added a little write up on how it's much simpler on later model cars so there is less confusion.
            Cheers!
              Both my mirrors are discolored, I will be using this diy. Thanks!
              2004 M3-Silver Grey Metallic/Imola Red-Coupe-6spd
              2002 330Ci-Topaz Blue Metallic/Black-5spd
              Instagram- Norocehcap
                Does your mirror have a slight vibration while driving? I recently replaced mine which also has the new method of attachment. I don’t think it’s as solid as the previous version.
                Current: 2003.5 E46 ///M3 6MT - 2019 Ford Raptor 802A
                Past: 2015 F80 ///M3 6MT - 2006 E46 ///M3 6MT - 1999 E36 ///M3 5MT - 1991 E30 ///M3 5MT
                  Awesome, thanks.
                  By any chance would anyone know what this little connector sticking out of the right hand side of my passenger mirror is?
                  Its been like this since I've owned the vehicle and all mirror functions work properly to my knowledge.
                    Looks like one of the leads for the heating element.
                      Try tightening the screws on the mirror base.
                      Evolve Eventuri
                        Awesome, thanks for that. I’ll try it out!
