19x10 +25 square
    19x10 +25 square
    Anyone running this, or close to it?
    I know 18x10 +25 is common, but I can't find any pics of 19x10 +25 square
    2004 Dinan S3-R M3
    2023 X3M Competition
    Should be the same as long as the outer diameter of the tire is the same.
      It can be done with ease on the rear, but the front is going get tricky. Compared to my fronts which are 19x9 et28 with 2 degrees camber you're going to have 16mm more poke and be inset 10mm more.
        They're off Paul Ehrlich's car, and he was running 19x11 +25 in the rear, and 19x10 +25 in the front. 275/30 & 245/35
        I can have them re-barreled, but IDK what size to go
        I was going to try to run 19x10 +25 square.
        2004 Dinan S3-R M3
          love Paul's work, but damn he runs aggressive setups on his personal vehicle, more stance than function
            Indeed. I have the Karbonius fenders, so that helps in the front. But these specs are still way too aggressive for anything but car shows.
            2004 Dinan S3-R M3
              why would you run a 10'' wheel for 245 tires?
                Because stance
                  My storage setup on my NA car is on squared rear OE CS/L wheels so that's 19x9.5 ET27 all around 275/25/19.
                  Slight rub at full lock but the car runs -3.5 up front and -2.5 in the rear and my ride height isn't broccoli'd.
                  2005 BMW ///M3
                  Black6MT Daily
